Diff lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rise007, Jan 23, 2020.
  1. Jan 23, 2020 at 4:31 AM
    Rise007
    Rise007 [OP] Well-Known Member
    2012 white Tacoma 5 speed manual
    My Tacoma 12 doesn’t have the diff lock option but I want to know how I can be able to make my truck lock it’s differentials
  2. Jan 23, 2020 at 5:08 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    you actually going to use it?
    One of my parameters when i bought my OR was the locker. I have yet to actually use it, other than couple times a year to see if it still works.
    whatstcp and TnShooter like this.
  3. Jan 23, 2020 at 5:12 AM
    Rise007
    Yes I am, I go off roading but what do I have to do to lock my rear differential
  4. Jan 23, 2020 at 5:17 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    reach out to ECGS, tell them your truck's specs, they will let you know your options
    https://eastcoastgearsupply.com/
  5. Jan 23, 2020 at 5:19 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    If your truck does not have the diff lock option, you have to get one installed.
    :spending:
    whatstcp, Pablo8 and JimboAnz like this.
  6. Jan 23, 2020 at 5:28 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    IF your truck has no locker first you will need to figure your budget and learn and choose what type of locker you want. Some great YouTube videos on this. E, Air, mechanical, Detroit, Lunch box, Torsen, etc
    Also you may want to think about a front locker.
    llamasmurf, whatstcp and DG92071 like this.
  7. Jan 23, 2020 at 4:27 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    The rear locker only works in 4L correct?
  8. Jan 23, 2020 at 4:46 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    No. An aftermarket locker can be used in any mode.
    Now that said - some gens and Toyota e-locker may only be engaged(used) in 4L (wired that way).
    whatstcp and rtilton12[QUOTED] like this.
  9. Jan 23, 2020 at 4:52 PM
    eon_blue
    Azusa, CA
    Toyota wired the rear elocker locker on TRD OR 4x4s to only engage when in 4lo....for 1st, 2nd and 3rd gens
    1st and 2nd gens can do a wiring mod to allow the locker to be used on 2wd or 4hi...but to my knowledge no one's figured that out yet for 3rd gens.
  10. Jan 23, 2020 at 5:23 PM
    rtilton12
    Robert
    Texas
    Thanks you guys!
  11. Jan 23, 2020 at 5:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Lots of guys have reported good luck with TrueTrac LSD.
    Although not a “true push button locker”. They are about as good as it get for LSD.
    And is bit less expensive and extensive to install than a Locker.
    I know you are wanting a True Locker.
    But I’m just throwing a different option out there.
    BTW, I have the factory locker.
    I rarely use it. I’d use a LSD more. I’m spinning one wheel unless locked.
    Later years had Electronically Brake Actuated LSD.
    But not 2005-2009 IIRC?
    whatstcp likes this.
  12. Jan 23, 2020 at 5:28 PM
    eon_blue
    Azusa, CA
    Ya the early 2nd gen Sports (2005 - 2008) had a true mechanical LSD. After 08 they no longer came with one, instead it's an electronic brake feature that mimics the action of an LSD
    Edit - maybe it was 2009 that was the last year, I can never remember
    TnShooter[QUOTED] and whatstcp like this.
  13. Jan 23, 2020 at 5:30 PM
    eon_blue
    Azusa, CA
    LSDs are ideal for better street traction, lockers are more ideal for offroad traction. If you prefer better street performance with some added offroad ability, an LSD is a good way to go.
    Lockers you don't want to engage on the street unless maybe you're doing a brake launch and trying to smoke your rear tires
    MSN88longbed likes this.
