Diff Locker
Discussion in 'New Members' started by LNorton, Jan 22, 2024.
  1. Jan 22, 2024 at 7:50 AM
    LNorton
    LNorton [OP] New Member
    Lee
    2014 Tacoma
    Lift kit, grill & light bar, nerf bars,whhels & tires
    Got a 2014 and looking for info on whether to install locker for all wheel drive? Looking for recommendations worth the cost or benefit?
    buckhuntin-tacoma likes this.
  2. Jan 22, 2024 at 8:05 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Your truck is 4wd, not All Wheel Drive. There is a difference. Are you talking about a locking diff for just the rear axle, or for both axles.
    A rear locking diff is one of those things that is really nice to have but is rarely used unless you do some pretty serious off-road driving. I've owned 4X4's since the 1970's and didn't own one with a locking rear diff until 2007. I've only used it a couple of times and could have managed without it then. But it did help, and I'd not buy another truck without it. Not sure I'd spend money to add one though. It would depend on the cost.
    Very few people use one in the front and rear. Only serious hard-core off-road drivers who often end up with one or more wheels off the ground at times can really justify them.
  3. Jan 22, 2024 at 8:47 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    LNorton[OP] likes this.
  4. Jan 22, 2024 at 8:56 AM
    545 Well-Known Member
    2015 Access Cab
    Rear lockers are very handy. Rear axle articulates more, so you get more out of a rear locker, and not a lot of negatives
    Front lockers (always do rear first) do help with traction but you really do need to be doing some pretty aggressive stuff to need it. They also make it harder to turn.
  5. Jan 22, 2024 at 9:36 AM
    LNorton
    Lee
    2014 Tacoma
    Great thoughts and appreciated. I have taken an earlier Toyota thru the Rubicon near lake Tahoe many years ago. Now located in middle TN and got 7" of snow. Would be nice to have extra traction but maybe not worth the cost. Maybe I'll add a winch down the road.
  6. Jan 22, 2024 at 9:48 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Another option to look into is a Detroit True Trac, I added one to the rear diff when regearing my truck.
  7. Jan 22, 2024 at 9:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I suggest you getting out there more and figuring out your truck's limitations (once you exceed it's capability).
    Upgrades are definitely nice and can make things easier for sure, but knowing what to upgrade first is always the million dollar question.
    Take it you drove a Land Cruiser as they're the only 'older' Toyotas I can think of that were full-time 4WD. Trucks would've all been part-time.
