Diff lockers and Cheetos
Discussion in '1st Gen. Tacomas (1995-2004)' started by MR2, Jan 13, 2016.
  1. Jan 15, 2016 at 1:52 PM
    #41
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Uhh...what??
    ARB is the strongest locker you can get and if installed right it's bullet proof.
    I got mine used for 450. Run it off co2 and it keep my lines dry.
    Pretty affordable if you look and find them.
    Yea the install is much more involved and not everyone can diy it. But so worth it. Fuck lunchbox lockers and having to totally change how you drive on the street and throttle out to get stuff to lock offroad. Push of a button at anytime for me and I'm locked.
    Elockers are actually...very finicky diffs and I've seen more of those blow up then any over Toyota diff. Including front diffs. Plus they don't lock immediately. Usually takes 10-20' for them to engage fully.
    david2011sr5 likes this.
  2. Jan 15, 2016 at 2:02 PM
    #42
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    My elocker enageged right off the bat evreytime and i beat the snot out of it for 10yrs and it worked flawlessly. I must have had an oddity or somehing.
    The failure modes i was referencing was there are too many variables that can cause them not to work.
    I agree that a selectable is great for a dual purpose truck and i sometimes miss mine, but people should know their downfalls.
    I have spoken heracy at tacoma world, i spoke ill of rhe arb... going to go all in, satoshis are ugly and retros are a waste of money... lol :D
  3. Jan 15, 2016 at 2:05 PM
    #43
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'll agree with the last statement..
    I've know over 15 elockers to have major issues be it diff issues like gears or the actuator.
    But I'll take any selectable locker over a mechanical any day either way. So much nicer all around.
  4. Jan 15, 2016 at 2:19 PM
    #44
    slander
    Hickory, NC
    I ran 200 whatever to 1 gear reduction through it and the diff held up fine and will be living on in a different truck. I think i changed the fluid once during that time and it was daily driven in the rust and salt belt. You witnessed 15 blow up?
    I would love a good solid (from a reliability standpoint) reasonably priced selectable as well.
  5. Jan 15, 2016 at 5:19 PM
    #45
    Wulf
    rock raisin
    I have had selectable lockers, automatic lockers, and a spool in my Jeep.
    Selectable is the way to go if you can afford it.
    If you want a cheap diff lock, I honestly preferred having a spool to an automatic (lunchbox or detroit) because the behavior is so much more predictable, especially in rain/snow.
    slander likes this.
  6. Jan 15, 2016 at 6:43 PM
    #46
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    No matter what, you can still rip an air line and be left locker-less. Weird shit gets kicked up while you're wheeling.
    I've never experienced having to "throttle up" off road to get either of my lunchbox lockers to lock. They always were locked when I needed them and only ratcheted on high traction surfaces.
    Toyota had a bad run of e-locker diffs in second gens that would blow up on the street. Not the lockers fault that Toyota didn't set up the R&P correctly. Properly set up an e-locker 8" is as strong as any v6 diff.
    The engagement mechanism isn't great if it isn't regularly used. They get sticky and corrode, no question. When used regularly, they work really well and you can always kick the slider over with a screwdriver if you are in a pinch. My locker is always on when I'm wheeling. Except for really tight turns on certain surfaces it's invisible and I never have to hear the peanut gallery when I forget to turn it on
  7. Jan 15, 2016 at 6:58 PM
    #47
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Chances of riping an air line is same as your chances of riping a brake line. Its not that big of a deal.
    Not sure what you mean by having to throttle out to get it to lock. With any reasonable amount of strain the diff is completely locked.
