Diff oil for locker?
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco, Jul 31, 2009.
  1. Jul 31, 2009 at 9:13 AM
    El Taco
    El Taco [OP] Well-Known Member
    STP MN
    Need help/advice in choosing rear diff fluid.
    I'm about to put a No-Slip locker in her (non-trd:().
    What diff fluid should I go with, considering I will now be running an automatic locker?
    Do I need to run some "additives" like LSDs?
    How many qts? (three?...from what I've been reading)
    Mobil 1 LS 75w90?
    Royal Purple 75w90?
    PS...also, will I be needing a new gasket for the third or just use some gasket sealer at the auto chain stores?
    -shanks, taco johns
  2. Jul 31, 2009 at 9:17 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    if you get RP you dont need aditive. 2 qts should do it
  3. Jul 31, 2009 at 10:26 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I just run Mobil 1 Synthetic 75w90in all 3 of mine.
  4. Jul 31, 2009 at 2:08 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    No-Slips could vary depending on the manufacturer of the unit.
    Call the company directly and ask them what type of oil they recommend and if you need additives.
  5. Jul 31, 2009 at 2:51 PM
    Beej222
    Beej222 Member
    BJ
    Hawaii
    01 xtra-cab 4x4 trd
    S/C, 3in lift, 32x11.5 on 15x8
    im using amsoil 75w90 in my rear end. and if yours chatters, you can just add some additive until it goes away.
    the fsm says to use hypoid gear oil API GL-5 You will need 3 quarts
    2WD: 2.75L (2.91q)
    4WD: w/o diff lock is 2.45L (2.59q)
    w/ diff lock is 2.75L (2.91q)
  6. Jul 31, 2009 at 4:12 PM
    El Taco
    STP MN
    upon thinking about which fluid visocity to put in.......
    should i just buy the "regular" diff fluid instead of the "sythetic" for the initial "break-in" period of the locker once installed, or go all out sythetic the first time around?
    ^^^i'm gonna go with 80w90 because of the bitch-ass cold winters here.
    -taco johns
