Diff question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thunder Fist, Mar 19, 2017.
  1. Mar 19, 2017 at 9:54 AM
    Thunder Fist
    Thunder Fist [OP] Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Can some educate me on this excerpt about different types differentials from http://www.tacomahq.com/4641/inside-tacoma-differentials/
    "Most 4wd trucks have a locking front differential as a standard feature. However, some vehicles – like later model TRD package Tacoma’s – have an electronically controlled front differential that can be locked or unlocked as needed."
    Does that mean that when I switch to 4WD my front diff automatically locks? I've never given much thought to differentials before so any help is appreciated.
  2. Mar 19, 2017 at 10:05 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    We have a locking rear differential if you have the off road trim. You have to lock the differential though by hitting the button, 4wd does not auto lock anything.
    You can add an aftermarket rear and/or front locker if you want, but if you need both a front and rear locker, you are into doing some serious shit.
  3. Mar 19, 2017 at 10:12 AM
    Rraiderr
    Rraiderr Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    My Jeep Wrangler Rubicon had both front and rear lockers, like said above I only needed to lock the front in extreme conditions.
    My 2017 TRD off-road was awesome in the last few snow storms. Plain old 4 hi is all it needed.
    Thunder Fist[OP] and Defuser like this.
  4. Mar 19, 2017 at 10:21 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Front Lockers are pretty rare, our beloved Tacoma's do not come with them but that does not mean you cannot add one.
  5. Mar 19, 2017 at 10:22 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
  6. Mar 19, 2017 at 10:23 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Yeah most 4x4 do not come with front lockers.
    Midknight and shakerhood like this.
  7. Mar 19, 2017 at 10:25 AM
    smitty99
    Scottsdale
    Power wagon does. Also has auto disconnecting sway bar I believe. Pretty impressive. The new ZR2 will have similar options too.
    Storman, George1441 and shakerhood like this.
  8. Mar 19, 2017 at 10:52 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    This article is extremely inaccurate.
    Most 4wd vehicles have open diffs. That is slowly changing since the introduction of the electronic locker. But front lockers are still fairly rare and that is also changing somewhat with OEM's trying to win on the spec sheet.
    Previous generation LSD's were clutch based and wore out and needed rebuilds to maintain that LSD performance or else they reverted to performance pretty much like an open diff. Companies like Detroit locker created a gear based LSD that works awesome for a LSD. But those are aftermarket and I do not know of any gear based OEM LSD but that may be my ignorance and not there may in fact be some on the market. Someone would have to chime in if they know more on this.
    The Tacoma LSD is more traction control than locker or LSD. Basically it uses the same systems as the ABS to control braking actuation instead of using components in the differential. Open diff (front) with brake assist to mimic LSD. Still effective but not a LSD. Now the TRD off-road does have an electronically controlled locker in the diff. Combine it with the LSD braking system and you have quite a combination.
    Thunder Fist[OP] likes this.
  9. Mar 19, 2017 at 12:21 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    So is Auto LSD on by default or do you switch it on?
  10. Mar 19, 2017 at 4:34 PM
    Exracer2
    Colchester Ontario
    I would check your manual. I know I would have to in order to answer your question.
  11. Mar 19, 2017 at 6:43 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    I believe its on all the time unless u hit the button on the roof(3rd gen). When it's sees it needs it a symbol flashes on the dash as its working. Now when u put it in 4lo it will show on dash 4lo, the letters LSD OFF and the symbol is on meaning it's off.
  12. Mar 20, 2017 at 10:11 AM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    The indicators are not always intuitive.
  13. Mar 20, 2017 at 10:36 AM
    thumpper
    thumpper Well-Known Member
    Bob
    Nebraska
    2008 Taco
    I learned it off of here actually.. the Tacoma from 2008 and older had a true LSD (maybe 2009 too) I just know that my 2008 had a true LSD/PosiTrac which worked great and didn't use the computer controlled brake set up. I would still prefer the LSD instead of the brake actuated b.s. I've never had an issue with mine and I also have it on a sports car with over 200k on the clock and still going strong.
    Since you are in the 3rd gen forum, if you don't have an electronic locker (OFF ROAD) you might have the brake actuated limited slip.
    shakerhood likes this.
  14. Mar 23, 2017 at 1:51 PM
    DoubleAction
    DoubleAction Well-Known Member
    Front lockers aren't cheap, I just priced them out and its around a grand.
  15. Mar 23, 2017 at 2:00 PM
    DoubleAction
    And that doesn't include labor :facepalm:
