Diff. Syn Intervals
Discussion in 'Technical Chat' started by papabear050, Nov 5, 2008.
  1. Nov 5, 2008 at 2:40 PM
    papabear050
    papabear050 [OP] Well-Known Member
    11 dc 4x4 TRD OR Auto
    SO how long can you go if you change the Diffrential Fluids, Xfer Case, and manny trans oil to sythetics such as Amsoil SG or Redline 75W-90 and MT-90
    I know it's every 30K on Dino oil, would syn extend that interval or change every 30.
    Also, lubbing the drivetrain throught he zerks is every 5K?
    Thanks.
  2. Nov 23, 2010 at 10:13 AM
    papabear050
    anyone? I have waited 2 years for a response. Hellooooo... .O...o_OoO...Ooo?
  3. Nov 23, 2010 at 6:07 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Afaik oil toyota uses in diffs is already a synthetic, so I would keep the same oil change interval
  4. Nov 23, 2010 at 8:49 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It depends on how you use your truck. Dusty conditions and water fording require more frequent changes/checks. So does towing.
  5. Nov 24, 2010 at 5:39 PM
    electricworktaco
    electricworktaco Member
    Ontario, Canada
    2010 sr5 4x4
    no way
    did you realy posted this 2 years ago
  6. Nov 24, 2010 at 6:36 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Only way to tell is to get Oil Analysis done.
    If they say the protection factors and life span indicators are good in the oil you drain- Go a bit longer and then get to analyzed again.
  7. Nov 24, 2010 at 7:04 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Toyota uses synthetic in the differentials?
