difference between 2.5" and 3" lift
Discussion in 'Suspension' started by ilovemytaco, Mar 12, 2009.
  1. Mar 12, 2009 at 10:00 PM
    ilovemytaco
    ilovemytaco [OP] Well-Known Member
    im getting frustrated with the mod bug...i want a lift but im lost
    i wanted to go with 2.5 bilstein 1500 and the tsb in back
    but i dont know if its the lift i want
    then i looked at the 3 inch spacer or coil lifts but there expensive
    so is there a difference in the .5 inchs i know its a little so i was wondering if pictures were decieving
    post pics if u can
    thanx
  2. Mar 12, 2009 at 10:02 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I'll have 2.5 with the TSB done on Monday, so I'll post pics when that happens. :D
  3. Mar 12, 2009 at 10:24 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    about 0.5" :D....sorry, couldnt resist....
    to your question, no, in the grand scheme of things, you will not notice the 0.5" at all (unless you actually bust out a measuring tape). i would HIGHLY recommend the 5100 lift. check out downsouthmotorsports.com, sonny is a great guy and seller and has made many very happy w/ his pricing and customer service.
  4. Mar 12, 2009 at 10:41 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    sonny got me my coilovers, good price too. :)
  5. Mar 12, 2009 at 10:43 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I have the 5100s, but I am planning on getting the 3 inch 5100 coilovers in the future.
  6. Mar 12, 2009 at 10:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The big difference is in how the vehicle is lifted. Spacers can make the ride pretty stiff as they preload (compress) the stock spring. The 5100's, while they still preload the spring, are valved for the preloaded spring rate. coill lifts (OME) or Coilover lifts, use a longer spring than stock, and, in the case of coilovers, have a shock correctly valved for the spring rate. the OME springs give the best ride when used with the OME shocks. For the best ride on and off road, coilovers or OME give the best results.
  7. Mar 14, 2009 at 10:19 AM
    ilovemytaco
    so how much would it be for the ciolover lift installed?
  8. Mar 14, 2009 at 10:25 AM
    bryan83taco
    bryan83taco Well-Known Member
    Cresview, FL
    06 TRD Off Road
    OME 885's,TOYTEC AAL, Nitto TG's, REAR 5100's
    With a garage, some basic tools and some mechanical common sense (?) you can do it on yourself. It's really not that difficult, give yourself the weekend to do it.
  9. Mar 14, 2009 at 10:37 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    The "Ultimate lift" from Toy Tec is $1100 and you could either call or e-mail your local offroad shop like 4wheel parts and ask how much for the install. Iam saving up for mine.
