Difference between 5/6 Speed Manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluejays, Apr 10, 2009.
  1. Apr 10, 2009 at 4:53 PM
    bluejays
    bluejays [OP] Well-Known Member
    Hi guys, I'm kind of new to manual transmissions and wanted to ask about 5 versus 6 speed manuals. What are the differences? Does it mean 6 speed is faster than 5 speed? What is the max speed for 5 speed manuals? Can a 6 speed go 90 and a 5 speed only 80? I was just confused on the differences between the two. Thanks for the help!
  2. Apr 10, 2009 at 6:22 PM
    geoff5093
    geoff5093 Well-Known Member
    Goffstown, NH
    2013 Subaru BRZ
    Well for one the 5 speed manual is only available in the 4 cylinder models, and the 6 speed manual is only available in the 6 cylinder models. I'm by no means an expert when it comes to transmissions, but the difference between the two is the gearing. For instance you can drive faster in 4th gear in the 5 speed then you can with the 6 speed without the RPM's getting as high, but it doesn't mean you can't go as fast. I'll stop talking before I dig myself in deeper, haha
  3. Apr 10, 2009 at 6:56 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    you get to shift 1 extra time with the 6 speed.:D
    The gear ratio's are closer in a 6 speed. Personally, it's just a gimick and not really needed for normal everday use. Offroad I could see some benefit with the closer ratios.
    SilverLightning likes this.
  4. Apr 10, 2009 at 7:33 PM
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    I personally have some complaints about the 6 speed, my biggest is that 1st gear is pretty much useless for street driving. You need to shift to second before you hit 10MPH and you can't downshift to 1st unless your going under 5MPH.
  5. Apr 10, 2009 at 7:39 PM
    tussery
    tussery Well-Known Member
    Corpus Christi, Tx
    09 PreRunner SR5
    Magnaflow muffler, TRD CAI.
    Looking at the gear ratios of the 6 speed I am amazed that there is such a gap from 1st to 2nd 4.17 to 2.19 is a huge gap to cover in one gear and the 5 speed is actually closer. But this is the difference between the transmissions in gear ratios.
    1st 4.17 3.52
    2nd 2.19 2.04
    3rd 1.49 1.40
    4th 1.19 1.00
    5th 1.00 0.72
    6th 0.85
    Turbo45 and Taco No Baka like this.
  6. Apr 10, 2009 at 7:57 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    No, the 6 speed is not faster, it simply offers more gear ratio choices.
    Is a 24 speed mountain bike faster than an 18 speed mountain bike ?
    No, just more gear choices to let your leg power be used more efficiently.
    Back to taco trannys, there's the take-off gear (1st gear), the intermediate gears, the 1:1 gear (where engine and driveline turn at same speed) and finally the overdrive gear.
    With overdrive gear, the engine turns about 20% slower than the driveline.
    Here's link to a discussion about these transmissions and their respective ratios. See post #4.
    Also there is info on the effect of the final drive ratio....that's the gear ratio in your rear (and front if 4WD) differential.
  7. Apr 10, 2009 at 8:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The 6 speed has reverse thru a detent on the left and forward insted of on the right side below 5th...
    But seriously- The past two posts were way better answers!!
  8. Apr 10, 2009 at 8:44 PM
    jflan
    Vancouver, WA
    Prolly safer to put it there....6th would be right next to it if it was in the same place as the 5spd. Imagine hitting reverse when you going for 6th !
    With the 5spd that area is vacant....makes it a good place for reverse.
  9. Apr 10, 2009 at 9:01 PM
    Some Old Blind Man
    Some Old Blind Man Got brake lights? Big ones??
    Valrico, FL
    08 2TR A.cab
    Elbow mod, DT Header, URD SS, Streetaco's radiator skidplate/guard, BHLM, Magnaflow
    I'm sure you found your answer, and by looking at the gear ratios, I'm glad I have the 5 spd. I only drive on road.. & sometimes wish the ratios were spread a bit more. What would really be a good tranny woud be a 6-spd with the 5-spd ratios, then have 6th around 0.50 (my estimate is that would put one around 1400-1500 rpm's at 70-75 mph... a good setup for Florida :devil: (and Illinois, Indiana, & the other flat-land states) :devil::devil::devil:
    Tennessee YODA likes this.
  10. Apr 10, 2009 at 9:02 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm surprised I haven't thrown the transmission on my scion yet- I used to have a 5 speed and an auto...Now I have a 5 speed and a 6 speed....Bad juju....:eek:
  11. Apr 10, 2009 at 11:06 PM
    bluejays
    can the 5 speed go 100 mph? what's the max speed 5 speed can go before it's getting bad for the car?
  12. Apr 11, 2009 at 5:51 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    X2. I have 5 speed and wish I had a 6th overdrive every AM when I hit the interstate on the way to work. It would be nice to save a little ga$ money.
  13. Apr 11, 2009 at 6:05 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Are you trying to set the truck up to race??
    For day to day-look at the manual for gearing speeds and and consider that there are lots of things that go into top speed...You trans can prolly handle more than your tires are rated for. Your clutch, brakes, shocks, oil, etc can all have issues as well.
    It can also handle more than your frame is designed to do-High speeds will feel VERY light, almost floating...and that is dangerous if you don't know what you are doing or you are in the wrong place (like public roads).
    If you are trying to race- you need to find someone nearby who also has a manual truck they race and learn from them..cause there is SO much more to consider than we can every tell you about on here....
  14. Apr 11, 2009 at 6:09 AM
    ryanf
    ryanf Well-Known Member
    NY
    06 AC 4X4 6cly/6spd TRD-OR
    Rain Visors,
    I hear ya! I love my 6 speed, but that first is Awful. My last truck was a 12V cummins, with a granny gear for first. Useless...but in my taco, second is two high to start in.....VERY MUCH A PIMA
  15. Apr 11, 2009 at 6:27 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...I usually skip shift to 3rd off of a high 1st or I find that I'm shifting almost constantly between rolling and like 12-13 mph.
    Anyone talked to Toyota about potential for changing out gears or multipliers??
  16. Apr 11, 2009 at 7:24 AM
    jflan
    Vancouver, WA
    This is from the link in post #4. As you can see both 5spd and 6spd have virtually the same OD gearing. In fact the 5spd is slightly taller!
    The 6spd is just split more in the intermediate gears as you can see.
    Aisin 5 speed
    R155:
    1 3.95
    2 2.06
    3 1.44
    4 1.00
    5 0.81
    Drive ratios (3.307 / 4.100)
    (Gear ratio * Final Drive)
    1 13.06 / 16.19
    2 6.81 / 8.45
    3 4.76 / 5.90
    4 3.31 / 4.10
    5 2.68 / 3.32
    Getrag 6 speed
    RA60:
    1 4.17
    2 2.19
    3 1.49
    4 1.19
    5 1.00
    6 0.85
    1 13.79 / 17.10
    2 7.24 / 8.98
    3 4.93 / 6.11
    4 3.95 / 4.88
    5 3.31 / 4.10
    6 2.81 / 3.49
    FD: 3.307 (4x2) / 4.100 (PreRunner/4x4) -> these are 4 cylinder model rear ends
    For max speed you have to factor in your gear ratio(s) and tire diameter (and redline :eek:) .....there's a chart around here somewhere for doing that.....it's used mainly when upsizing tire size and changing gear ratios to accomodate.
  17. Apr 11, 2009 at 3:26 PM
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    When I'm driving at 60MPH in 6th gear my RPM's are almost always around 2K. I wish there was another gear for even more fuel savings!
    Yeah, I really don't prefer to start off in 2nd unless I'm going at least 5MPH. I usually tend to shift from 1st > 2nd > 3rd > 4th by the time I hit 30MPH, but I almost always skip 5th gear.
  18. Apr 11, 2009 at 5:04 PM
    jflan
    Vancouver, WA
    Yeah, I've driven the 6spd and I don't like that first gear....too deep for a normal take-off gear and to tall to be a true granny, IMO.
    If 1st is too deep and 6th is not tall enough, one solution is to re-gear the differentials. The gear shops (Randy's Ring and Pinion) have calculators to help you decide on which gearset is best for your application.
    I can say that 1st gear in the 2.7L 4x4 with 4:10's is about perfect for a normal 1st gear (stock tires). I would do the math and try to emulate that as the driver in the formula, then take however taller 6th ends up to be.
    Focus on that take-off (1st) gear.
    Larger tire diameter would be another way to go.
  19. Apr 11, 2009 at 6:06 PM
    bluejays
    are the top speeds of the 6 gear the same as the top speed of the 5th gear? i'm trying to drive on the I-5 from LA to Sacramento and I was wondering if I can go 100 mph with the 5 speed since there is going to be no one on the road. at what speed can i go at until it starts to become bad for the car?
  20. Apr 11, 2009 at 6:11 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The point where it becomes bad for everyone is right about the SPEED LIMIT. That's a good place to stop accelerating.
