Difference between 5100 and 5125 in rear
Discussion in 'Suspension' started by headhunter247, May 20, 2009.
  1. May 20, 2009 at 6:25 PM
    headhunter247
    headhunter247 [OP] Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    What is the difference between the 5100 and 5125 in the rear? I know that the 5125 is longer, but what benefit would it give me to put the 5125s in the back vs 5100. Im buying a new house, so the OME kit is out. Im at looking at 1.75 to 2.5 in the front (prob 1.75) and AAL in the back.
  2. May 20, 2009 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 5100's and 5125's are valved the same, but the 5125's require the use of an adapter to fit the stock top mount. Personally, the 5100's are good for up to 2" rear lift. Im running the 5100's in the rear and am quite happy.
  3. May 20, 2009 at 6:28 PM
    headhunter247
    St. Louis, MO area
    You know its funny, I almost just PMed you instead of posting because I knew you would know..ha.
    Thanks sir.
  4. May 20, 2009 at 6:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  5. May 20, 2009 at 6:32 PM
    headhunter247
    St. Louis, MO area
    1 more question for you....1.75 or 2.5 in the front. I drive a TON to work and back. I dont want to risk any driveline vibrations. I might go the 285 route. Maybe a silly question, but what about a little bigger like 275? I alss have the dreaded bump on takeoff. Ive checked everything, and nothings loose.
  6. May 20, 2009 at 6:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The higher you lift, the more firm your truck will ride. 285's will fit, but you will rub alot. Also, the higher you lift, the more Caster you loose, and may have some wandering when on the road. 275's would be a good size, but I think its kinda rare.
  7. May 20, 2009 at 6:37 PM
    headhunter247
    St. Louis, MO area
    Yea, I never really heard much about 275. Now to the other part. I have the dreaded bump on stop and takeoff. I have read alot about axl wrap etc. I have checked everything and nothings loose. Now what?
  8. May 20, 2009 at 6:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If its the bump that happens on stopping AND starting, it may be the slip joint in your drive shaft..You need to take it apart, and put some grease in it.
  9. May 20, 2009 at 6:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    did you install an add a leaf yet?? if not......installing one will help alot with axle wrap.
  10. May 20, 2009 at 6:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    this is a good idea too....i had to do mine when i first got my truck...and it helped a bit.
  11. May 20, 2009 at 6:40 PM
    headhunter247
    St. Louis, MO area
    Nope, not yet. Is this bad?
  12. May 20, 2009 at 6:41 PM
    headhunter247
    St. Louis, MO area
    Is there any pics of this? Im not real good on a truck, as this is my first, and only had front wheel drive cars prior.
  13. May 20, 2009 at 6:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i didnt take pics, but basically,what you do........where the drive shaft goes into the rear diff..........you'll break the 4 bolts loose on the knuckle and take the shaft apart. then...you'll clean the area real good-i had to run some sandpaper around mine cause it was real rusty-, then you'll reinstall the shaft and grease it. you will need to put the truck in neutral....and do all this on a flat surface....so you can get the shaft to line back up.
  14. May 20, 2009 at 6:52 PM
    headhunter247
    St. Louis, MO area
    Say Im not real keen on doing this. How much do you think a shop would charge?
  15. May 20, 2009 at 6:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that i couldnt really tell ya, since rates are different everywhere. now...if you have a trusted mechanic somewhere close by.....im sure they would work with you on good price to do it.
  16. May 20, 2009 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What Will said, and to add, A drive line shop would be the best bet, or If there are any members in your area that could lend a hand. :) Be sure the Drive shaft is lined up EXACTLY how it was when removed, or vibes may be present.
  17. May 20, 2009 at 7:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i shoulda mentioned lining it back us as it came off...................i marked mine with a yellow paint pen so it went back the same way it came off.
  18. May 20, 2009 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Perfect. :)
  19. May 21, 2009 at 5:17 AM
    headhunter247
    St. Louis, MO area
    Thanks fellas. Greatly appreciated. Im not sure that I can tackle this on my own. As far as members go, I know there is only one and hes not that close.
  20. Nov 10, 2010 at 8:09 AM
    disassemble
    disassemble Well-Known Member
    NJ
    2012 double
    just ordered 3/4th hour glass bushings from 4wheelparts.com done deal.
