Difference Between Adjustable Front 5100 and Coil-overs?
Discussion in 'Suspension' started by GatoFeo, Mar 5, 2019.
  1. Mar 5, 2019 at 11:54 AM
    GatoFeo
    GatoFeo [OP] New Member
    Remington
    Issaquah, WA
    01 Auto V6 4x4 Xtra Lunar
    Slightly too large of K02s, 1" spacer lift
    Bought this set from Down-South Motor because it seemed like a good sale and I have a twitchy trigger finger. I don't do enough off-roading in my DailyDriver '01 to constitute coil-over prices but I wonder what their advantage is over the shocks I just bought. Isn't the double-wishbone in my 1st-gen an OEM non-adjustable coil-over? Isn't this shock set more convenient for me to start with since I can change the coils for OME 2882 or 2883s later if I get armour?
    Don't care for leveling, looking for on/off-road comfort and performance.
    Sorry if I missed a thread that covers this, I searched for a while. Thanks!
  2. Mar 5, 2019 at 12:03 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Correct, your truck currently has non-adjustable coilovers.
    Theones you linked are also coil overs, just adjustable, and not pre-assembled. And yes, it is more convenient because you can swap springs and preload adjustment. This set should do great for you uses based on what you describe
  3. Mar 5, 2019 at 12:10 PM
    GatoFeo
    Remington
    Issaquah, WA
    Thanks! That helps a lot but I still wonder what the higher-price built coil-overs are for, I guess they're expected to be for higher performance needs?
