difference between grilles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingN8, Dec 6, 2008.
  1. Dec 6, 2008 at 1:00 PM
    kingN8
    kingN8 [OP] Well-Known Member
    Southern Mississippi
    05 Impulse Red Corolla S
  2. Dec 6, 2008 at 1:15 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    i think you want the 3rd one, the 4th says 'non-SR5' in the fit comments. i dont think you'll need any other parts than whats on the truck from the stock one but i've never installed one of these particular grilles.
  3. Dec 6, 2008 at 1:25 PM
    kingN8
    u think i should let a body shop install it??
  4. Dec 6, 2008 at 1:37 PM
    RelentlessFab
    Eric
    well if it installs the same way as a stock one, as i'd imagine it does, then it should take about 5 minutes to remove the one on your truck and put this one on. fits by a centering pin on the bottom, a few clips and two screws on top to hold it down. all you need is a flat screwdriver to pop the plastic clips up, and a philips screwdriver for the two screws on top.:D
  5. Dec 6, 2008 at 3:21 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    The forth is a "RADIATOR GRILLE ASSEMBLY"
  6. Dec 6, 2008 at 8:51 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  7. Dec 6, 2008 at 10:19 PM
    kingN8
    thanks for the shipping info..prolly not gonna order from there then;)
