Difference between long travel and mid travel
Discussion in 'Suspension' started by Annolino122, Sep 26, 2013.
  1. Sep 26, 2013 at 7:28 PM
    Annolino122
    Annolino122 [OP] Well-Known Member
    Evansville
    2014 Tacoma TRD off road
    I was searching through some threads about LT and MT suspensions, already deciding on my stage 5 icon MT.... is all it takes to make it a LT kit is the wider UCA's and LCA's? aside from hardware to remount things, is that essentially the difference?
  2. Sep 26, 2013 at 7:38 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total chaos UCA's, icon coils, deaver leaf pack with icon resi's
    No the shocks are diffrent aswell mid travel consists of a stock length uca normally with a uniball and a extended travel 6 in coil. Where long travel is anywhere from 2 to 4 inchess wider then stock depending what kit you run with 8 in coils
  3. Sep 26, 2013 at 7:38 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    Can't find the stage 5 on their website.
    LT uses 2.5 8-10" coilovers, and yes, longer uca's and lca's.
  4. Sep 26, 2013 at 7:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    and longer CVs if your 4wd..
    and extended steering
    and about 4-6'' more travel.
    and about 3000 bucks more..or so..give or take.
  5. Sep 26, 2013 at 9:33 PM
    Annolino122
    Evansville
    Stage 5 is just 2.5 inch reservoired icon shocks in the back instead of the 2.0 inch.
    SDHQ off-road has the higher stage kits
    http://store.sdhqoffroad.com/2005-currenttacoma0-35suspensionsystemstage5.aspx
    but if you get the extended travel coil overs and shocks like i am that add 1.5 inches of travel to the coil over than essentially, with the wider UCAs, LCAs, and other parts like blackdawg said, they're pretty much the same set up, just paying for LT conversation later on won't be as damaging to my bank account.
    their rep at icon said the extended travel Icon coil overs can get up to 10 inches of travel
  6. Sep 26, 2013 at 9:35 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I'd save up and do it in one go, if you're already planning on LT
    I spent way too much money swapping suspensions up to MT; switching to LT would be way worse
    nothing translates over from MT to LT, especially if you're going to run it hard.
    you can't use "normal" MT exptended coilovers with a LT kit
  7. Sep 26, 2013 at 9:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No you'll still need a different coil over too. The Mid travel coil overs are 6.25'' of travel.
    Long travel coil overs at 8 or 10'' of travel.
    you can't use the mid travel coil over with a LT kit. Won't work.
    You bank account is gonna take a hit no matter what. Its why not everyone does it.
  8. Sep 26, 2013 at 10:00 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Stage 5 kit is plenty to get your di*k wet especially in AZ......can hit the fast stuff and still crawl through tight rocky trails. Do it right the first time and got Stage 5 but add a full replacement leaf pack and Icons bolt on hydro bumps. The rear will take all the abuse off road so don't skimp there. LT front is useless if the rear cant keep up!
  9. Sep 26, 2013 at 10:37 PM
    Annolino122
    Evansville
    thats why im going with the stage 5 MT... i was just curious about the LT kit just to see if you could do the swap. I plan on doing more trails and crawling then high speed dunes and wide open areas. The width of the truck is perfect for what i do so no need for the LT, just curiosity
    but sublime... what are you talking about for the rear? i that the 2.5's and the add-a-leaf was the suggested way to go if i didnt want to remount and reframe my back end?
  10. Sep 26, 2013 at 10:40 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    a full leaf pack will always outperform an AAL on a weak stock pack
    unless you're going LT, or want a custom setup outback, you don't have to change anything with the rear frame
  11. Sep 26, 2013 at 10:43 PM
    Annolino122
    Evansville
    so getting an all-pro rear leaf kit for the $450 is worth it than actually paying the $150 for AAL
  12. Sep 27, 2013 at 7:58 AM
    Big Taco
    Big Taco Well-Known Member
    Justin
    Hampton, VA
    06 Tacoma TRD Sport DCLB
    King 2.5 Remote resi Coilovers w/ 700# spring. Rear All Pro Expo leafs All pro front bumper ARE Bed cap Pro comp wheels
    Always
  13. Sep 27, 2013 at 10:28 AM
    Annolino122
    Evansville
    Had a PM about a pack that won't jack up the back end of my truck and more forgiving than the stiff all pros
  14. Sep 28, 2013 at 3:43 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    The aal with the 2.5" rears will actually do pretty good but the stock leafs with aal can't take a ton of punishment. Bottoming out is a major issue with these trucks as we don't have a ton of compression travel so a better bump stop is usually needed. Those 2.5's properly valved will help with bottomimg out so I would just roll with that for awhile or feel you need more out of the rear.
