Difference between mid and long travel?
Discussion in 'Long Travel Suspension' started by gacandido2010, Dec 12, 2011.
  1. Mar 20, 2012 at 6:15 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    Very true . ^^
  2. Dec 9, 2017 at 6:45 PM
    Jultepod
    Jultepod Well-Known Member
    Oahu, Hawaii
    2013 Gray Tacoma TRD
    K&N cold air, Exhaust, rims and tires, 3" king extended travel coilovers and total chaos UCAs, rear diff breather mod, CBI off-road ditch brackets with Cali raised LED pod lights and painless wiring harness, 4xinnovations rock sliders, cab mount chop.
  3. Apr 17, 2018 at 1:51 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Not to thread jack, but I have a couple first gen mid travel questions if someone feels up to satisfying my curiosity. Are extended CVS necessary for mid travel? Will the factory CVS hold up to the extra angles? Does mid travel require fenders as well or can you just trim and put a bigger bump stop in?
    I thinking I'd like to do a mid travel setup by the end of the year, but I just put a set of 5100s in and noticed how tight the CVS are at full drop. They still rotate smooth, but seem to be at their limit.
  4. Apr 17, 2018 at 7:49 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The cv boots rubbing and wearing holes are what limits most of the lift you can get with a mid travel setup. Depending on what size tires you run you can put on fiberglass fenders, cut the stocks, tub the firewall (with 35's), etc. It really depends on what you see happening when you cycle the suspension.
