difference between OME leaf springs cso45r and cso47
Discussion in 'Suspension' started by Mudsaucecoma, Apr 30, 2013.
  1. Sep 7, 2013 at 9:33 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    $499
  2. Sep 8, 2013 at 4:30 AM
    pbcolt
    pbcolt Well-Known Member
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Sorry, I meant ordering a set of Alcan leafs from Alcan which can handle extra weight, but only provide 0-1" of lift, not the set that wheelers offers.
  3. Sep 8, 2013 at 3:19 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Wheeler HD packs are made by Alcan.
  4. Sep 8, 2013 at 4:29 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    And provide 0-1" of lift?
  5. Sep 8, 2013 at 7:56 PM
    OZ-T
    Peter North
    British Columbia
    Yep , one of the leafs is removeable
  6. Sep 9, 2013 at 8:29 AM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Really? I thought these were just a cheaper Dakar alternative, providing the same heights as Dakars with and without the removable leaf.
  7. Sep 9, 2013 at 8:35 AM
    OZ-T
    Peter North
    British Columbia
    You said you wanted less lift than the Tacoma Dakars give but with a greater hauling capacity than stock , that's what the Wheelers HD pack provides , and if you want less lift from them you can remove one of the leafs
    Did you go to the link I provided and read the info ?
  8. Sep 9, 2013 at 8:52 AM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    I did, but they don't provide any lift numbers, just say it will ride higher than stock depending on load. That could mean 3" or .5". I'd ideally like to be where the TSB pack sits, a little higher than my 2+1 pack, and be able to load up camping gear without bottoming out over a Ticonderoga pencil.
  9. Sep 9, 2013 at 9:00 AM
    OZ-T
    Peter North
    British Columbia
    I would suggest calling or emailing Wheelers
  10. Sep 9, 2013 at 9:09 AM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Already have. I'll follow-up with their reply in case anyone else is interested. Thanks for the help as usual OZ.
  11. Sep 9, 2013 at 11:07 AM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    From Dan at Wheelers:
    "With our HD pack, if you remove the 3rd leaf, it will be about 1.5" of lift.
    For your situation, I would recommend the standard 3 leaf aal set. Maybe
    just use the upper two leafs from the set to not get the full 1.5" of lift."
  12. Sep 9, 2013 at 5:07 PM
    splitbolt
    NW Arkansas
    So, lift-wise, they're similar to Dakars...3rd leaf removed on my Dakars gave me about 1.75".
    Since the Wheeler pack uses less leafs for about the same amount of lift, they are probably stiffer than the Dakars.
  13. Sep 9, 2013 at 6:45 PM
    OZ-T
    Peter North
    British Columbia
    Why don't you just ask Wheelers what the spring rate is
  14. Sep 23, 2013 at 3:00 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Hilux rear leafs other than the eyelet size are not dimensionally compatible with our Tacomas. This per ARB USA. FYI.
  15. Sep 23, 2013 at 3:06 PM
    #35
    OZ-T
    Peter North
    British Columbia
    Case closed
  16. Oct 29, 2013 at 5:58 PM
    #36
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    #36
