Difference between strut extender and coil spacer?
Discussion in 'Suspension' started by Deuxdiesel, Aug 9, 2010.
  1. Aug 9, 2010 at 4:23 AM
    Deuxdiesel
    Deuxdiesel [OP] Well-Known Member
    SE MI
    '12 Silver Streak stocker
    I'm looking for a mild front lift (2-2 1/2") for my 09 DC with TSB springs. From what I gather, the Toytec style spacer goes on top of the coil itself, while the Fat Bob style mounts on top of the entire strut assembly. I've read tons of posts (all of them are fairly subjective, naturally), but I'm looking to see if one style has more negative effects on alignment or other components than the other. While I won't be doing any rock crawling, I will be doing some mild off-road driving to access biking, camping and climbing areas. I understand UCA's and a diff drop may be needed. Thanks in advance for constructive input.
  2. Aug 9, 2010 at 8:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do some searching.... lots of info out there already.
    Search for these words......
    "Top plate spacer" <---- goes ontop the assembly
    and
    "Coil Spacer" <--- goes inside the coil assembly
    Try using Google also.
  3. Aug 9, 2010 at 11:17 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Preload, and Top-spacer. Both provide lift. A kit that acheives lift via all top-spacer though does tend to have some issues with upper balljoints and other things, Pre-load spacers tend to give a harsher ride. Your best bet is to get either Bilstein 5100 shocks that can provide up to 2.5" of lift, or an OME setup to do the same.
  4. Aug 9, 2010 at 1:25 PM
    Janster
    Jandy
    Lancaster, PA
    Coil spacers & Bilstein 5100's do the same thing......preload the coil.
    Both can give harsher ride quality. THe only difference between the two - is the 5100's are adjustable.
    If you have a 2.5" coil spacer compared to the 5100's set at 2.5" lift - they preload the coil the same amount. The ride quality will vary based on the struts themselves and not the coils.
  5. Aug 9, 2010 at 9:24 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    would it be okay to set 5100's to .85" with sagged 885 coils? my coils have sagged over the past 3 years. i wanna get my full 3" back.
  6. Apr 3, 2017 at 11:58 AM
    verdegreene14
    verdegreene14 Active Member
    Brian
    Central, AZ
    08 Black Taco Turd
    Giggity
    2.7taco likes this.
  7. Apr 3, 2017 at 3:22 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Thread revival?
  8. Apr 3, 2017 at 5:03 PM
    verdegreene14
    Brian
    Central, AZ
    08 Black Taco Turd
    No. Im just a child, sometimes. What I gathered was that top spacers can mess stuff up, preloads make it stiffer and don't break things?
  9. Apr 3, 2017 at 6:29 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    They're both shitty lifts, but a cheap way to gain clearance for tires. Not recommended for off-roading. You can break shit with either lift or no lift at all.
    verdegreene14[QUOTED] likes this.
  10. Apr 3, 2017 at 7:35 PM
    2.7taco
    Texas
    It only preloads the coil springs if the spacer is between the top plate and the spring.
    I've gotten my truck airborne, hit large holes at high speed and the ball joints are still tight. My bushings have finally gotten tired but other than that all is well. It has held alignment over the years as well. So as far as breaking stuff you would have to get pretty wild.
