Difference between Toytec/Eibach and 521600 coils
Discussion in 'Toytec Lifts' started by TN_Tacoma, Nov 14, 2016.
  1. Nov 14, 2016 at 12:31 PM
    TN_Tacoma
    TN_Tacoma [OP] Well-Known Member
    David
    New Jersey
    07 Taco PreRunner SR5 DCSB
    K&N CAI, MBRP Cat-Back Exhaust, 265-75-16s Nitto Terra Grappler, Tuff A.T. 15s 16 inch wheels, 1.25" wheel spacers, black bumper, bumper light bar in grill, CB radio, Aftermarket speakers and 2 10 inch subs, LED odometer mod
    Looking at getting a 3" lift for my truck and came across two lifts from toytec. Both with the bilstein 5100 lift like many 3" lifts i have seen on here, only difference I see at first glance is one has the Toytec/Eibach coils and the other has the 521600 coils. Can one of yall please explain the difference to me?
  2. Nov 16, 2016 at 8:56 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Hey,
    I can explain the differences. I assume you are talking about the Bilstein lift kit and the Toytec 3" lift kit. Ill start with the Toytec 3", it uses a bilstien 5100 shock with a 600lb coil to give some lift and uses out own Toytec aluminum top hat for the full 3 inch lift. The Bilstein kit uses the same 5100 shock but uses a 620lb coil which is going to be slightly stiffer and with a stock style top hat you will receive 2.5 -3 inches.
    Let me know if i can explain any further.
  3. Jan 25, 2017 at 11:14 AM
    Longshoreman
    Longshoreman Well-Known Member
    CA.
    2013 Tacoma off road & tow package
    Toytec coilovers Fabtech uca's Dakars and 5100's in the back.
    Can the top hat be removed on the 521600 to get 2.5 instead of 3"?
    NC Rick likes this.
  4. Jan 25, 2017 at 11:17 AM
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    wondering the same
  5. Jan 25, 2017 at 11:21 AM
    Toytec Lifts
    Rocky Mountains
    I do have this kit that has you use your stock top hat and i USUALLY see about 2.5" out of it yes.
    Longshoreman likes this.
  6. Apr 29, 2020 at 3:47 PM
    99Runner3.4
    99Runner3.4 Well-Known Member
    Lucas
    2009 4x4 TRD Off Road DCSB
    Are the 521600 coils pigtail top and flat on the bottom? I have the eibach 2.5” leveling struts(EIB E60-82-007-02-10) and need coils for them but they are flat on the bottom and pig tail (stock top hat) on top. Thanks for the help!
