Difference between Trac and VSC
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheNewSled'16, Jan 12, 2016.
  1. Jan 12, 2016 at 7:09 AM
    TheNewSled'16
    TheNewSled'16 [OP] Active Member
    Bobby
    NY
    2016 Barcelona Red TRD Offroad Double Cab Short Bed Tech & Premium
    What are the differences between the traction control and VSC on the 2016 Tacoma? And What situations would you turn these options off?
  2. Jan 12, 2016 at 8:23 AM
    TheNewSled'16
    Bobby
    NY
  3. Jan 12, 2016 at 8:25 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    To do donuts in some guys feild:)
    TheNewSled'16[OP] and GoodOlBoy like this.
  4. Jan 12, 2016 at 8:27 AM
    TheNewSled'16
    Bobby
    NY
    Tear it up!! Hold down the vsc trac button haha:mudding:
  5. Jan 12, 2016 at 8:29 AM
    Broccoli
    Airdrie Alberta
    There is a really good second gen post that talks about vsc, trac, worth a read.
  6. Jan 12, 2016 at 8:30 AM
    TheNewSled'16
    Bobby
    NY
    Oh okay that makes sense thanks man
  7. Jan 12, 2016 at 8:31 AM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    so your suggestion would be to turn it off for the above situation then?
  8. Jan 12, 2016 at 8:41 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    you need to be stopped to turn off VSC completely.
    TRAC is not just traction conrol. Traction control is a part of VSC. TRAC is a braking system that tries to keep the wheels turning at the same speed. Braking is applied to wheels that are turning faster than the others. Engine power can also be cut to reduce wheel spin
    I am waiting patiently for someone to try the locker anytime mod on a 2016
  9. Jan 12, 2016 at 8:55 AM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    and the advantage of that is? *I'm not being a smartass
  10. Jan 12, 2016 at 9:09 AM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    cool, thanks....now to look at that mod and see if it can be applied to the '16
