Difference between TRD and SR5 4x4's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lee Vining, Mar 25, 2018.
  1. Mar 28, 2018 at 3:18 AM
    LenaSayre
    LenaSayre New Member
    Lena
    Hi there, I have recently joined this forum.
  2. Mar 28, 2018 at 3:43 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Welcome to tw highly recomend in not getting the running boards look for a set of sliders instead. Unless you dont go offroading much.
    FROM1978 likes this.
  3. Mar 29, 2018 at 6:25 PM
    Lee Vining
    Lee Vining [OP] Active Member
    Jckdnls.............not sure what sliders are these may be those....will post pics after the fact
    leev
  4. Mar 30, 2018 at 3:26 AM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    These are sliders it protects the truck better. Bolts or welds to the frame. Called sliders cause u can slide the across rocks or curbs n do no body damage. Also if a lifted truck saves against door dings. Thinking about making my own since i cant find one i like.
  5. Apr 5, 2018 at 8:28 AM
    Lee Vining
    OK.................got the side rails put on and the Snug Top as well, took some advise found here and got weather guard mats...going to try and post pics.....is there a tutorial somewhere for adding pics?
  6. Apr 6, 2018 at 12:33 PM
    Lee Vining
    JimboAnz: the service folks opened the driver side door, reached under the lower left of the dash, pushed a button on the security switch and presto the horn no longer toots when locking with fob....If I wish it to, I simply press the button again....
  7. Sep 27, 2018 at 11:36 PM
    Lee Vining
    OK.....well I didn't get any feedback on photo posting so I'll see what I can do.........since we last talked the truck has been to Ariz, Colo., Utah, Nev., Wyom., and Idaho, NMex......and Eastern Sierra's x 3. Runs, drives great....tho there is a stumble problem when the accelerator is stomped on......I saw a discussion on that and copied the pdf....I'll take it to the dealer. I am now interested in leveling the suspension and putting larger tires on....say 825's....with Bilstein adjustable shocks on the front and 7.5 - 8 inch rims. Let me see if I can post pics.....[​IMG]
  8. Sep 28, 2018 at 9:25 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    In the 3rd gen there is a menu screen on the dash that allows you to adjust that.
  9. Sep 28, 2018 at 10:29 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The horns in my truck do not make any noise whatsoever when I lock or unlock the doors. There is however the little chirp sound but its not related to the horns.
