Difference between two of your kits
Discussion in 'Toytec Lifts' started by KPT, Feb 7, 2012.
  1. Feb 7, 2012 at 10:44 AM
    KPT
    KPT [OP] sees what you did there.
    09 Prerunner
    Toytec,
    I've recently seen folks asking folks opinions on this kit below:
    3" lift kit with Bilstein 5100 Height adjustable Coilovers
    Just for my information, and to help answer others questions when they pop up, can you tell me what the difference is between the above kit and this one:
    Bilstein Adjustable lift kit with 5100 shocks
    I see that both come with the same coils and shocks. The only difference that I see is that the one that's $170 more comes pre-assembled, and with a spaced top-mount to achieve 3" of overall lift. Am I missing any other differences? Thank you.
  2. Feb 7, 2012 at 10:46 AM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    I think that's it. But with the adjustable shocks and coil I am not sure you need the spacer. But I guess toytec knows more than I
  3. Feb 7, 2012 at 11:04 AM
    KPT
    09 Prerunner
    Well that's another place where I'm confused.
    In the second kit it says "3 inch average lift is achieved with coils and setting the shock adjustment on the second C clip setting from the bottom", which is 0.85" of lift. Pair that with the 620# eibach coils, which provide 1.6" of lift as noted here:
    http://www.toyteclifts.com/index.ph...tegory_id=115&option=com_virtuemart&Itemid=72
    0.85 + 1.6 = 2.45", so that doesn't add up.
    The first kit says it comes pre-assembled to achieve 3" of lift, which I assumed was Bilsteins at 0.85, 1.6" lift coils, and a 1/2" spacer at the top of the assembly. 0.85 + 1.6 + 0.5 = 2.95"
    So I'm not adding something up correctly here.
  4. Feb 7, 2012 at 11:23 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Would someone with this lift please step up? I dont have the lift but toytec is the one I am going to get. Thanks for looking into this
  5. Feb 7, 2012 at 11:29 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    The pre-assembled lift comes with a thicker top plate to put you at a true 3" of lift. It's got the standard 5100's set at .85, Eibach coils and Toytec's thicker top plate.
    The non-preassembled kit uses the same 5100's, you get to choose the setting and re-use your old top plate. With this set-up, even with the 5100's at .85, you'll end up shy of 3" (despite what their website says).
    The difference between the 2 kits is the thicker white top plate (and assembly).
  6. Feb 7, 2012 at 11:40 AM
    KPT
    09 Prerunner
    That's what I was seeing as well I just figured I was missing something due to the fairly large price difference between the two.
  7. Feb 7, 2012 at 11:52 AM
    Pugga
    Massachusetts
    Well, two differences I guess, using your own top plates vs. getting new ones. Then the labor to pre-assemble the parts.
  8. Feb 8, 2012 at 5:36 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    The top plates and top spring rubber are not that cheap. Then add the labor for those who do not have the ability and it is a fair deal.
    I thought about it but am a cheap fucker so will be doing it myself and only want them set to 0 for the lowest 1.6 lift.
  9. Feb 8, 2012 at 8:05 PM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    You can get the other set assembled by toytec for 100.00 extra charge. the preassembled kit also comes with axle shims as well. The preassembled kit will be 2.25 or 3" lift (just specify if u want the 5100's set 0 or .85)....the un-assembled kit can be 1.6(set 0),2.4(set .85), or 3"(set .85 w/ tp spacers) depending on what you order. I have called toytec and this is what they said
  10. Feb 9, 2012 at 9:19 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    You guys have got it pretty much figured out.
    The TTHA-CK kit already comes assembled with the ToyTec aluminium top mounts, axle shims, and U bolts.
    The cost for the parts separately is
    $200 for the top mounts
    $39.99 for the U bolts
    $29.99 for the shims
    Add that to the BK0510 which is 629.99 and you get 899.97 so we are throwing in the assembly labor for free (or 3 cents if you want to be specific :D).
  11. Feb 9, 2012 at 9:24 AM
    KPT
    09 Prerunner
    Thanks for your response.
  12. Feb 13, 2012 at 8:12 PM
    whitmextaco
    whitmextaco Active Member
    Houston
    White TRD Double cab short bed 4x4
    None
    Do you really need those parts on a 11 tacoma off road with 6k miles?
  13. Jul 1, 2012 at 9:14 PM
    xsptaco07
    xsptaco07 Well-Known Member
    Jordan
    Atlanta
    2007 Tacoma Xsp
    xsp package, 20" enkei deep six wheels,33" cooper zeon ltz, borla exhaust, borla intake, carbon fiber trim, weathertech mats, Halo HID lights, black grille surround with mesh, smoked 3rd break and tails, 3" toytec coilovers with bilstein strut, AAL and bilstein 5160 in the rear, led tag lights, led interior lights, NTW plated bumper, anytime fog mod, blue and white cluster swap, UWS toolbox,
    i ordered lift number 1(3" lift kit with Bilstein 5100 Height adjustable Coilovers) and will be installing it on wednesday. wish me luck!
  14. Jul 1, 2012 at 9:21 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    If you want it to come assembled, yes.
    I did on mine, different kit but it was a lot easier to install by just bolting parts on rather that disassembling parts to get the ones you need to assemble your new parts.
  15. Jul 1, 2012 at 9:48 PM
    amocat 777
    amocat 777 Well-Known Member
    Tacoma Doublecab
    I bougt the Ultimate lift for my first gen. Completely happy w Toytec ! Bilstein shocks have handled abuse well, good ride on and off road.
  16. Jul 1, 2012 at 10:00 PM
    RIDDICK3
    RIDDICK3 nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    how is the ride on and off road with that second choice lift on a dbl cab?
  17. Aug 17, 2012 at 8:04 PM
    kyser13
    kyser13 Well-Known Member
    09 Tacoma/SR5 4X4
    Debadged, Inno bed rack blacked out brackets, Blacked out front Toyota badge, Interior red LEDS, 285/17-70 Duratracs, 17X9 Moto Metal 957s, Toytec 3" lift Bilstiens, Ultra Gauge, LED bed lights.
    I just recieved the kit in question can I be sure to get the full 3" of lift with it?
  18. Sep 13, 2012 at 12:19 PM
    grady77
    grady77 Member
    glendale az
    2008 Tacoma 2wd PreRunner TRD Off Road access
    Toytec TTHA-CK 3" lift
    yes. i didn't measure, but mine looks like MORE than 3. More like 3.5
  19. Feb 7, 2013 at 3:16 PM
    MidnightTaco
    MidnightTaco Member
    Elliot
    Vacaville, California
    08 Prerunner
    Bully bar, Many to come
    hey fellas,
    What does it mean when you set the 5100's at .85? What does the .85 represent? Thanks all!
    Doing lots of research so I can lift my truck :)
  20. Feb 7, 2013 at 3:21 PM
    MidnightTaco
    MidnightTaco Member
    Elliot
    08 Prerunner
    Also...I was reading the it says you can adjust the lift from 1.75 to 3''. How is that done?
