Difference in Tacoma packages
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Knapin15, Nov 28, 2024.
  1. Nov 28, 2024 at 2:41 AM
    Knapin15
    Knapin15 [OP] New Member
    What is different in the Tacoma packages, which ones offered rear lockers? And what came with the off road package? That’s unique to the others? Thanks!
  2. Nov 28, 2024 at 4:02 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The TRD OR is optional 4wd, has an electronic rear locker, additional traction control modes, and a 4-wheel independent electric over hydraulic brake booster. You can add lockers to other trucks (air is probably the most popular) but retrofitting the ATRAC system is not cost feasible and is extremely involved.
    TRD Sport is also edit: optional 4wd, 05-08 (and supposedly some into 09) has a true LSD, something changed with that I believe in 09 so someone else will have to chime in. The Sport has a cosmetic hood scoop.
    TRDs are also all SR5 trim as well I believe.
    The other differences between the OR/Sport are in the factory shocks and coils, which at this point if you're buying 2nd gen will be due to be replaced if they haven't been already.
    Tow package (transmission intercooler, hitch, wiring)/4wd/SR5 are also available as separate adds to any Tacoma, you'll have to look carefully at the options and/or run the VIN to see what they have/are supposed to have.
    Dm93 likes this.
  3. Nov 28, 2024 at 5:38 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Not all OR, or sports are 4x4, OR package is the rear locker with 4x4 option, and Atrac. SPORT has no locker also 4x4 option no Atrac.
  4. Nov 28, 2024 at 7:13 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Rear locker is exclusive to TRD OffRoad and TRD Pro (2015+) models, 05-08 TRD Sport Models had a mechanical limited slip rear axle. All 09+ models have simulated limited slip using the ABS/Traction Control.
    If you want to see what was available on each year with each package have a look through the brochures.
    https://www.tacomaworld.com/threads/tacoma-ebrochures-2001-to-2017.486957/
    winkel and SethM like this.
