difference of off set
Discussion in 'Wheels & Tires' started by cantac09, Oct 25, 2010.
  1. Oct 25, 2010 at 10:26 PM
    cantac09
    cantac09 [OP] Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    right now on my truck i have moto metal 955's that have a -12 off set and 4.5 inch backspacing. i need to have 4.5 inch backspacing because of my lift. i am looking for some winter wheels and im looking into the atx mojave and they have the same back spacing but instead of a -11 off set they have a 00 off set. so what i am wondering is what will the difference be? and really what the hell does off set mean?
    thanks
  2. Oct 25, 2010 at 10:38 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Off set is the difference between the the hub mounting surface and the center line of the wheel, the back spacing is the dsitance from the hub mounting surface and the inner bead (0n the outside not the actual tire seat).
  3. Oct 25, 2010 at 10:40 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    so what will the difference in looks be?
  4. Oct 25, 2010 at 10:41 PM
    08pretaco
    08pretaco IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    o offset with a 4.5 bs is a true 4.5 bs. a 4.5 bs with -12mm offset is 5 bs IIRC
  5. Oct 25, 2010 at 10:43 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    well i just need to have 4.5 inch backspacing it didnt mention anything about off set. so i should be ok then?
  6. Oct 25, 2010 at 10:44 PM
    08pretaco
    Oliver
    az
    ya as long as bs is 4.5 and nothing is mentioned of offset
  7. Oct 25, 2010 at 10:45 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    ok thanks for your help
  8. Oct 25, 2010 at 10:46 PM
    08pretaco
    Oliver
    az
    im running 951 with 4.5 and when i had my OME 3" worked out very well!
  9. Oct 26, 2010 at 6:10 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Backspacing is calculated by using offset and rim width. If the two wheels you are looking at have the same backspacing, but a different offset, then by definition the wheels are not the same width. Check this chart (1/3rd down the page) to double check that both you are looking at are 4.5" BS.
    http://www.rsracing.com/tech-wheel.html
  10. Oct 26, 2010 at 7:24 AM
    08pretaco
    Oliver
    az
    Haha i was hoping you would chime in! I have to remember that website
  11. Oct 26, 2010 at 7:29 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Backspacing is backspacing regardless of offset. 4.5 BS is 4.5 BS no matter what the offset is.
    Visual reference:
    https://www.rsracing.com/tech-wheel.html
    offset
    Backspacing
