Difference prerunner / non-prerunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sqdqo, Jun 5, 2011.
  1. Jun 5, 2011 at 5:29 AM
    sqdqo
    sqdqo [OP] Member
    I just want to know the difference between the Tacoma preunner and non-prerunner.
  2. Jun 5, 2011 at 5:42 AM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    Go to the dealership and grab one of its brochures. They list them side by side what is standard and optional.
  3. Jun 5, 2011 at 7:53 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    The prerunner is just like the 4X4 but is only a 4X2.The non prerunner sets lower to the ground and has 15 inch tires and wheels and no finder flares..
    Fight4Function likes this.
  4. Jun 5, 2011 at 7:58 AM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    Prerunner is the exact same as a 4x4 (suspension, wheels, and tires.) with the exception of NO front differential (2 wheel drive).
    A NON Prerunner truck is commonly referred to as a "5-lug". All 5-lugs are 2 wheel drive.
  5. Jun 5, 2011 at 8:27 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    can you add the finder flares to any truck?...:D
  6. Jun 5, 2011 at 10:06 AM
    WV150
    South Carolina
    I don't know.If I wanted them I would just get a prerunner.I think the prerunner looks much better than the 5 lug truck but looks do not matter to some as long as it gets the job done.My daughter looks at a car as only a transportation pod to get you from here to there.Can't understand that but to each his own.
    Everett07 likes this.
  7. Jun 5, 2011 at 12:51 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    Simple answer, no.
    Many have tried . . . All have failed.
    It's a turribull turribull death. (As Charles Barkley would say)
  8. Jun 5, 2011 at 3:17 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    There are non-prerunner 2wd 6 lug Tacomas available.
    Edit:
    Mea Culpa. Went to the Toyota website and everything that is not a 5 lug or a 4x4 is now called a Prerunner. When I shopped for my '09 you were able to buy a 6 lug 4x2 that wasn't called a Prerunner. Now you can't.
  9. Jun 5, 2011 at 5:15 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    all i have to say is get the truck that has 6 lugs, not 5. you will beat yourself up if you plan on buying aftermarket suspension parts as the 5 lugs do not have a big of a product availability at the 6 lug do.
  10. Jun 5, 2011 at 5:17 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    He said it.
  11. Jun 5, 2011 at 7:47 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    x3^ the only reason I have a 5-lug is because it was a gift. It's getting traded for a 4x4 2nd gen the moment I have the money.
  12. Jun 5, 2011 at 8:56 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Can you describe Finder flares?
    just fukn with ya...:homer::rofl:
  13. Jun 5, 2011 at 9:00 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    End of thread.
  14. Jun 6, 2011 at 5:37 AM
    WV150
    South Carolina
    What I think he means is the factory flares that are on most of our trucks.Maybe it is a SR5 thing.
  15. Jun 6, 2011 at 5:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It's tough to add factory flares to 5 lug tacomas. The trucks that have them have punched body panels and the holes are square so they'd be tough to recreate. I'm sure you could find some way to attach factory flares, but to do it the way the factory intended would be more work than it's worth in my opinion.
  16. Jun 6, 2011 at 6:15 AM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    Prerunner has : fender flares, 16 in wheels, 12.56 in disc brakes in front, looks like the 4x 4 but ain't.
  17. Jun 13, 2011 at 11:10 PM
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    What exactly is different about the suspension on the PreRunner compared to a 5 lug?
  18. Jun 14, 2011 at 10:18 AM
    DanglingFury
    Keith
    2006 4Runner 4x4
    The 5 lugs sit roughly 5 inches closer to the ground compared to the 6lug trucks. their suspension is also better suited for offroad, better springs, better shocks. They're just a bit tougher and more heavy duty in general.
  19. Jun 14, 2011 at 12:00 PM
    JDCPA
    Jim
    SW FL
    IIRC the leaf springs for the rear axle mount underneath the rear axle for th e 5 lug and on top of the rear axle for the 6 lug.
  20. Jun 14, 2011 at 12:49 PM
    oldstick
    oldstick Medicare Member
    GA
    I think your daughter is a very smart lady in that case. To me all Vehicles are money pits due to the high depreciation factor. On top of that, they carry the hiqhest loss risk (due to crash/theft) of anything most of us own.
    I also like to have a nicer looking vehicle BUT I normally can afford just a tad more than the cheapest cars on the market. And I need a reliable small truck with 4 doors, so I also have the Pre-Runner TRD/Sport as opposed to the base.
    But a lot of folks would be wiser to heed your daughter's philosophy. Get only exactly what you need and no more because cars are for your basic transportation requirements and money spent above that level should be considered disposable income like hobbies and entertainment. I see so many people, including myself several times, sink endless $$ into dressup wheels, accessories and so forth only to get totaled two months later. And even best case, the whole package is still a $1500 junk-beater within 10 years or so.
