Difference with high octane?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Austin09, Sep 8, 2016.
  1. Sep 8, 2016 at 12:35 PM
    Austin09
    Austin09 [OP] Well-Known Member
    Austin tx
    2016 Barcelona Red TRD access can LB
    T-Rex grill with black bezel. Blacked out all the badges and added the Tacoma on the tail gate. The windows have been tinted to the darkest law will allow.
    does anyone run high octane, and if so is there a noticeable difference.
  2. Sep 8, 2016 at 12:37 PM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    No
    No
    Mark77, 0210 and sadmrhappy like this.
  3. Sep 8, 2016 at 12:37 PM
    98tacoma27
    Ben
    Not Beech Creek
    High octane should only be used if your engine specifically calls out for it's use or you are experiencing ping (pre-detonation). Other wise it is a waste of money.
    Mark77, 22Coma6MT, hiPSI and 3 others like this.
  4. Sep 8, 2016 at 12:39 PM
    eon_blue
    Azusa, CA
    You're going to get a lot of "no and no"'s and "yes and yes"'s with this thread, and a ton of arguing and BS'ing in between. Good luck
    FWIW I run high octane fuel because supercharger. But I do know some people that run mid-high octane in their N/A trucks and swear by it
  5. Sep 8, 2016 at 12:39 PM
    98tacoma27
    Ben
    Not Beech Creek
    You forgot butt dynos.
    Old goat1914, SH10151, Ch78 and 2 others like this.
  6. Sep 8, 2016 at 12:45 PM
    Austin09
    Austin tx
    thanks, I ran it in my 03 chevy and it helped but it had 170,000 miles on it. I knew TW would set me straight.
  7. Sep 8, 2016 at 1:42 PM
    4RNR
    4RNR トヨタ
    Ge
    America
    16 Tundra 1UR-FE | 10 4Runner 1GR-FE | 16 2GR-FKS DCSB 4X4 - sold
    2016 Tundra crewmax
    After running full tank of V-Power my engine knocks like crazy. Can't say for sure if that is because of that gas but knocking increased a lot.
    I got so mad that I went to look at tundras....:D:p:thumbsup:
    AH99 likes this.
  8. Sep 8, 2016 at 2:16 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    I run 100% pure gas, 91 octane....I get over 25 mpg but it's also for piece of mind.
    Technically it's probably not worth it penny for penny but it works for me.
  9. Sep 8, 2016 at 2:18 PM
    jg16
    jg16 Well-Known Member
    Tennessee
    2016 White Off Road
    I ran 93 octane in a Ford Ranger for a few years. Gas went up so I went to 87 octane. Truck acted like I filled it up with water. Guess they get used to the high test gas!
    cryptolime likes this.
  10. Sep 8, 2016 at 2:30 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Toyota R&D has dyno'ed this new engine to death. Two-bits says thousands of hours.
    If their data indicated it would perform better with higher octane, it'd be in the truck's manual and their advertised performance figures would reflect the added performance.
    Or at least that's what I think...
    SB
    Gravytrain912 and 0210 like this.
  11. Sep 8, 2016 at 3:08 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I use 93 non-ethanol.
    If I used E10, I would still use 93 to insure octane, against water contamination(>10% ethanol).
    Ideally, from a station that sells it on a regular basis.
    Ethanol blends only last about 90 days under ideal conditions.
  12. Sep 9, 2016 at 10:05 AM
    robertbank
    robertbank Well-Known Member
    Bob
    Terrace, BC
    Ordered TRD Sports DCLB Upgrade Pkg
    Why do folks think a higher octane rating will get you better gas mileage? The Octane rating reflects the timing of when the fuel will ignite. It has nothing to do with the amount of energy the fuel produces. Just saying.
    Take Care
    Bob
  13. Sep 9, 2016 at 10:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    Because advertising
  14. Sep 9, 2016 at 10:09 AM
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    I am truly struggling to make any sense of this...
    BC Hunter likes this.
  15. Sep 9, 2016 at 10:10 AM
    imdav2u
    imdav2u Well-Known Member
    St. Louis
    2016 TRD Offroad DCSB 4X4
    If you want better gas mileage find a station that sells 100% gas with no ethenol. It's hard to find but in my experience my trucks get at least 2 mpg's more.
  16. Sep 9, 2016 at 10:11 AM
    robertbank
    Bob
    Terrace, BC
    Ah yes. I heard Shell puts little people from Ireland in their gas and the little buggers run 10% faster than ESSO fuel's PQU additives. ;)
    Take Care
    Bob
    WilliamJames likes this.
  17. Sep 9, 2016 at 10:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    :rofl:
  18. Sep 9, 2016 at 10:19 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    No. ECU and motor are set up to use 87 octane. Anything more is indeed a waste of money. However, what's not a waste of money is ethanol free gas or 100%. Gas has more energy in it than ethanol so you get less powerful explosions in the cylinder with ethanol mixed gas. Plus, if even minute amounts of water are introduced to gas containing ethanol, phase separation can occur. This can create problems throughout the fuel system. This problem is far more common in boats because the chance of water entering the system is more likely and boats often times sit for extended periods of time which makes phase separation worse.
    Even so, most gas sold in the US is E10 or 10% ethanol so the difference between E10 and 100% gas is pretty minimal. Not like you'll notice a difference and if you daily drive your vehicle phase separation will never be an issue. 100% gas is normally 91 or 93 octane as well and significantly more expensive than E10 87.
    BC Hunter and shakerhood like this.
  19. Sep 9, 2016 at 10:23 AM
    mcadori
    mcadori Active Member
    2016 Inferno 4x4 AC TRD OR
    I run 88 Octane, because the manual calls for min. 87 and low-test here is 86. I've found that when I run 86, the engine has a little less torque and doesn't hold a gear as well as with 88. Driveability is a little better with mid-grade for me, but I'm at 5000 ft of altitude. YMMV.
  20. Sep 9, 2016 at 10:25 AM
    splitbolt
    NW Arkansas
    Not to nitpick, Toyota states;
    -Minumum, 91 octane RON
    -Does not recommend ethanol blend fuel
    If contamination does occur, what happens to the octane of 87 E10 when its ethanol content drops below 10% due to phase seperation?
