Difference??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Audible, Nov 21, 2007.
  1. Nov 21, 2007 at 8:50 AM
    Audible
    Audible [OP] Well-Known Member
    Southern Califonia
    2006 PreRunner TRD Off Road
    DRL's, 04 TRD Off Road bed stickers, Tow pkg, Penzoil synthetic oil, partially debadged.
    What is the difference between a TRD Sport and A TRD Off Road? I mean aside from asthetics (stickers, tires, hood scoop). The engine is the same. i even think the suspension is the same...since many of us are getting the TSB performed.
    Anyone have spec sheets to compare???:confused:
  2. Nov 21, 2007 at 10:24 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    TRD Off-Road Package (OC) -- SR5 Package #2 plus off-road tuned suspension with Bilstein® shocks, 16-in. alloy wheels with P265/70R16 BFGoodrich® Rugged Trail T/A tires, locking rear differential, engine skidplate and fuel tank protector, front tow hook, 115V/400-watt deck mounted power outlet, multi-function overhead console with compass and temperature gauge, sport seats with sport fabric and driver's lumbar support, and TRD Off-Road graphics (V6 models)
    TRD Sport Package #1 (PY) -- Sport suspension with Bilstein® shocks, 17-in. alloy wheels with P265/65R17 tires, limited-slip rear differential, 115V/400-watt deck-mounted power outlet, fog lamps, power windows/door locks/outside mirrors, remote keyless entry system, cruise control, variable intermittent windshield wipers, multi-function overhead console with compass and outside temperature gauge, color-keyed grille surround/bumpers/mirrors/door handles/overfenders, sliding rear window with privacy glass, sport seats with driver’s lumbar support and sport fabric trim, metallic-tone instrument panel trim, leather-wrapped steering wheel and shifter, sun visors with sliding extensions and vanity mirror, hood scoop, and TRD Sport graphics (V6 models)
  3. Nov 22, 2007 at 9:17 AM
    Audible
    Southern Califonia
    Looks like everything is exactly the same except for the color-keyed parts and the wheel/tires. Suspension is the same too. Looks like the marketing genius at Toyota pulled the wool over the consumer's eyes again?:eek:
  4. Nov 22, 2007 at 10:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Look at the list that jhodge83 posted.....
    The main difference:
    The TRD offroad comes with a selectable locker
    THe TRD Sport comes with Limited slip
  5. Nov 22, 2007 at 10:16 AM
    The_Hodge
    SC
    yeah...the main thing is that locker vs. the limited slip....but it also says sport tuned vs. off road tuned...i wonder if there is a difference in the coils?
  6. Nov 28, 2007 at 8:18 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    From what i've heard the off-road has beefier springs
  7. Nov 28, 2007 at 7:08 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Suspenson is basically the same for both TRD's except the offroad has the variable wound front springs, and the sport on road has a few mm thicker front sway bar. A V6 non TRD model after the TSB will have the straight wound coils of the on road sport with the small front sway bar of the offroad model.
  8. Nov 28, 2007 at 7:24 PM
    The_Hodge
    SC
    i thought that the non-trd's only got the shocks up front, not the coils as well?
  9. Nov 28, 2007 at 7:40 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    They do just get the shocks, but the non TRD's V6 models have the same front springs as the on road sport models. The "tuned" suspension on the on road sports is bilstein shocks and a bigger front sway bar. The "tuned" suspension of the off road pkg is Bilstein shocks and variable wound front springs. So if you install the Bilstein shocks front and rear on a V6 model you will have the same suspension as the on road sport model, minus the larger front sway bar, order the larger front bar and your suspension will be the exact same as the on road sport TRD (but of course not trim, wheels, tires etc.). You could order the variable wound front springs over the parts counter and have the exact suspension of the off road model (minus trim items).
  10. Nov 28, 2007 at 7:42 PM
    The_Hodge
    SC
    ahh...good to know
  11. Nov 28, 2007 at 8:06 PM
    07TACOTRDSPORT
    07TACOTRDSPORT Active Member
    MOORE, OK
    07 PRERUNNER SR5 TRD SPORT X CAB
    PIONEER AVIC D3 GPS XM RADIO
    hood scoupe, color coded mirrors / bumpers (TRD Sport), Raised White Letter Tires (Off Road)
  12. Nov 29, 2007 at 7:43 AM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    That's great info, thanks!
    Now, excuse my ignorance, but am I right that the sway bars are for tighter cornering? I'm pleased with my off-road's cornering, but it's interesting to know I could improve it.
  13. Nov 29, 2007 at 11:54 AM
    nd
    Nate
    Greenville, SC
    good info LRH, thanks!
  14. Nov 29, 2007 at 10:52 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    That info is from the Toyota supplied info, and of course they tell you what they want you to know, or what they think is important. I supplemented this info by crawling around and looking at the front spring paint codes at several dealers, mostly at Atlanta Toyota since they have around 100 or so Tacomas at any time (about 35-40% 4WD & PreRunners). Attempted to do the same with Tundra rear leaf packs, but gave up in frustration due to too many small subtle variations in the overload leaf and the length and thickness of the bottommost (non overload) leaf in the main pack.
  15. Nov 30, 2007 at 2:10 AM
    ERdept
    ERdept Well-Known Member
    The locking differential is more capable for off-road than the limited slip.
    Is this correct?
  16. Nov 30, 2007 at 7:19 AM
    nd
    Nate
    Greenville, SC
    yes
