Differences: 1997 2.7L vs 2001 2.7L
Discussion in '1st Gen. Tacomas (1995-2004)' started by cab4you26, May 17, 2011.
  1. May 17, 2011 at 7:14 PM
    cab4you26
    cab4you26 [OP] Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    Alright I've been searching Craigslist high and low for a motor for my truck. Finally I find a guy close to me who has a 2.7. My truck is a 1997 and his is a 2001. I know some have 4 and 8 port intakes, but are there any other major differences in the two? Would I be able to use the short block from this truck (or even the long block?). The guy claims it has only 12k on the motor and says he can verify that, however he can't start it due to an electrical concern. He is only asking 800! Any advice?
    http://lynchburg.craigslist.org/pts/2386303720.html
  2. May 18, 2011 at 11:55 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    lol u can get the whole engine for like 6-700 used.
  3. May 18, 2011 at 4:14 PM
    cab4you26
    Corey
    VA
    Yeah I haven't quite figured out what or how I'm going to offer if I do. He said the wiring harness is messed up and it won't start because of this. And technically the motor is used, but everything I have found is usually in the $1500-2000 range and either has high miles or is a rebuild. I could get a brand new short block for 2k. If this deal is as nice as it sounds then that's a steal. He told me he bought the whole truck because he flipped his 2003 and needed a door and some other parts, and he said I could pull the valve cover to get somewhat of an idea of how it was taken care of/actual miles.
  4. May 18, 2011 at 4:22 PM
    YFZ_TRD
    YFZ_TRD 4Runner Pilot
    Lee
    Beaverton, OR
    2014 4Runner SR5
    X2 a 2001 with 12K and just an electrical problem sounds good to be true
  5. May 19, 2011 at 6:07 AM
    cab4you26
    Corey
    VA
    He said the parts truck was hit from the side and he bought the whole truck. I think I might still take a look even though I told him I wasn't interested yesterday. Mike from LCE told me the motor should work fine.
  6. May 19, 2011 at 9:07 AM
    cab4you26
    Corey
    VA
    SOOOOO I just looked in the For Sale section of TW and this guy is a member on here!
