Differences between the 3rd gen Tacoma years?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcardoso12, Feb 13, 2020.
  1. Feb 13, 2020 at 7:34 PM
    #41
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    That's not an update. That's an accessory add on.
    I never use the sliding window in my Tundra. Don't miss it at all in the Taco.
    shakerhood[QUOTED] likes this.
  2. Feb 13, 2020 at 7:35 PM
    #42
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Never heard of any TSS issues. Some people prefer not to have “nanny electronics”, but I don’t think there are issues with it. My 2018 has never had any issues with TSS.
    BSFord, Junkhead and IEsurfer like this.
  3. Feb 13, 2020 at 7:37 PM
    #43
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Right for someone that doesn't use it then it definitely wouldn't be a big deal, I personally like it in my truck and use it frequently and would not want to climb in and out of the back seat.
  4. Feb 13, 2020 at 7:37 PM
    #44
    2016Tacoman
    J
    Break down and also that tech will change drastically every year from now. Better hardware, algorithms, etc.
  5. Feb 13, 2020 at 7:39 PM
    #45
    2016Tacoman
    J
    Why do you use it ? When I had it on another truck years ago all crap would blow in from the back sometimes. No thanks.
  6. Feb 13, 2020 at 7:40 PM
    #46
    shakerhood
    Southern Ohio
    With the sunroof and back window open you get nice airflow, also is nice to have open on its own when the temp is not warm enough for the AC.
  7. Feb 13, 2020 at 7:43 PM
    #47
    2016Tacoman
    J
    I must be abnormal. I have a sunroof in my car and I have used it probably 2 times in 10 years.
    Only time I open it is to clean the crap out of the drain tubes so it doesn't back up and flood. Probably wouldn't get it on another vehicle.
    Ainapo and shakerhood[QUOTED] like this.
  8. Feb 13, 2020 at 7:46 PM
    #48
    shakerhood
    Southern Ohio
    I didn't think I would like it very much but ended up loving it, I try to open it whenever I can, kinda nice to even slide the sunshade back in the winter too.
    MOC221_ likes this.
  9. Feb 13, 2020 at 7:47 PM
    #49
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Pre 2018 you can avoid the retarded TSS and a beeping sound everytime a squirrel darts in front of you....
  10. Feb 13, 2020 at 7:50 PM
    #50
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    To clarify about TSS for 2018+ trucks. Most are upset because swapping to PRO Grille is more difficult.
    I didn't swap my grille, I lifted my truck 2.5 inches, and all systems work great. Truck beeps when a jackass in front of me is braking out of nowhere. Also get cruise control that follows the car in front of you.
    It is nice to have.
    BSFord, TacoMamba35, MOC221_ and 2 others like this.
  11. Feb 13, 2020 at 8:00 PM
    #51
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    If you want the upgraded safety (TSS) but don't want to buy new, just buy a 2018.
  12. Feb 13, 2020 at 8:05 PM
    #52
    brandon78lusch
    Brandon
    I installed a trd pro grille on mine and my tss sensor works but it randomly starts beeping and telling me to brake even when I'm on an empty road, it sometimes even applies the brakes for no reason due to the tss functions (I have the sensitivity set to the lowest setting). I might upgrade to the 2020 trd sport/OR grille so I don't have to deal w/ it
  13. Feb 13, 2020 at 8:08 PM
    #53
    Superdave1.0
    SoCal
    If you have my same grille, have you thought about going back to the stock grille?
  14. Feb 13, 2020 at 8:09 PM
    #54
    brandon78lusch
    Brandon
    I never liked the stock grille tbh, the 2020 stock grills look a lot nicer. I still have my stock 2019 grille just in case I need to put it back on
    Superdave1.0[QUOTED] likes this.
  15. Feb 13, 2020 at 8:09 PM
    #55
    Superdave1.0
    SoCal
    They probably slide right in. I'm curious if someone has tried.
  16. Feb 14, 2020 at 4:58 AM
    #56
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    My Tss has never gone off (knock on wood) except when traffic made a sudden stop in front of me and I had to slam on the brake. I do use the Smith system when driving (keep a decent following distance, etc)
  17. Feb 14, 2020 at 6:46 AM
    #57
    Ghostrider52
    Ghostrider52 Well-Known Member
    Nick
    Tampa, FL
    2020 Toyota Tacoma TRD Off-Road AV4
    6” Zone Suspension Lift 20” Fuel Rebel Wheels 305/55r20 Falken Wildpeak AT3W Tires
    I wasn’t in the market for a Tacoma, but when I started to do some research i found they hold their value so well that buying relatively used (within 5 years) doesn’t save a bunch of money, especially if you are financing. Over the long run the new ones seem to be the way to go, one reason I moved to Toyota from Chevy.
  18. Feb 14, 2020 at 6:47 AM
    #58
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    The less electronics the better imo. I got a 17 with 30k miles for $26k and that was at the very top of my budget. If you don't mind all the electronic bs then go for an 18+. I just didn't want to deal with breaking sensors and control modules in 5-10 years. 2017 to me is the sweet spot for the third gens. Has all the nice updates that the 16s lacked but doesn't have the safety bs.
  19. Feb 14, 2020 at 6:56 AM
    #59
    Joe.Dirt
    Joe.Dirt Well-Known Member
    Colorado
    '19 Cavalry Blue TRD Off Road DCLB
    All these people complaining about TSS and I've never had an issue. Period.
    Love BSM for backing out of my driveway. Love adaptive cruise control. Adaptive cruise control is everything I ever wished crusie control would be.
    BSFord and TacoMamba35 like this.
  20. Feb 14, 2020 at 7:00 AM
    #60
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I love how everyone thinks the TSS adds a ton of unnecessary electronics. These trucks are rolling computers. A few extra sensors doesn't change that. I'll take auto brights and ACC every day on the off chance it has an issue a decade from now.
    2Dayvid, BSFord and Joe.Dirt like this.
