Differences(if any) with the LIMITED suspension vs TRD Sport???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SteelerJim, Mar 3, 2016.
  1. Mar 3, 2016 at 11:19 PM
    SteelerJim
    SteelerJim [OP] Well-Known Member
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    ARE Overland Topper, WeatherTech Mudflaps
    I just bought a new 2016 Tacoma Limited. I realize the TRD Off Road has the bilsteins, rear locker and crawl control. But what is the difference with the Limited suspension vs the TRD Sport? Is there any??? DSCN1603.jpg
  2. Mar 3, 2016 at 11:30 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    with the sport probably nada, with the offroad alot.
    nice rims btw.
    SteelerJim[OP] likes this.
  3. Mar 3, 2016 at 11:44 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    The limited has the sr5 suspension. The sport has the Hitachi blue shocks, which are "sport tuned"
  4. Mar 3, 2016 at 11:47 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    I haven't even looked at the shocks really to see what they are. Thanks for the info! Question... Will my ride improve much if I change out to the Bilsteins that are on the OffRoad? Or maybe the 5100s that you can get aftermarket? They sound like a popular choice. I appreciate all the info...
  5. Mar 3, 2016 at 11:52 PM
    stan23
    stan
    Santa Clara, CA
    I would not bother changing to the billsteins that came with the OR. I'd go 5100s if I were to go aftermarket. Bonus is that the front shocks allow height adjustment, so you can "level out" your truck.
  6. Mar 3, 2016 at 11:58 PM
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    I've heard people refer to the aftermarket Bilsteins as .85s or 1.75s. Is this actually the same shock and you simply adjust the amount of lift before you install them? Or ???
  7. Mar 4, 2016 at 7:28 AM
    Sawick
    Sawick Still not worthy!
    JB MDL, NJ
    16 TRD Sport
    T4R TRD Pro Wheels, LED lights, Tonneau Cover, ICI running boards, AVS window/bug
    Correct, the .85 and 1.75 are the settings on the shock. (ride height)
  8. Mar 4, 2016 at 7:28 AM
    pocketsmcaaron
    pocketsmcaaron Well-Known Member
    Oregon
    '16 OR MT DCSB WHT Prior:'15 MT ,'94 MT
    Snugtop Rebel,TRD Pro Bilsteins,2" Block rear,SR Grill,TRD Beadlocks,Toyo AT 2s,Focal Experts,Kicker AmP & 10" Sub
    I swapped the Trd off-road shocks as thought they were descent, but too stiff. Went for '15's Trd Pro suspension with red coils: 2.5" front, 2" rear with reservoir. Imo, ride's like a magic carpet and clearance is perfect for my needs. If you don't like rear lower desert stance: either add u-bolt block 1"-2"depending on how much weight's going to be carried or leafs. Btw would have preferred Leaf(s), but voids toyota warrenty-lame.
    Trd4u of Dallas $1599 plus $350 installed. 2" Rear blocks were around $120, level's out perfect with shell.
