Differences in 5100 shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spencer4x42006, Jan 28, 2018.
  1. Jan 29, 2018 at 6:16 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Valuable info all the way around is that you can mess shocks up short or long by not limiting suspension travel either in droop or compression and using the shocks as the limiting factor.
  2. Jan 29, 2018 at 6:24 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    If you read my original post it is all about the amount you are going to lift the truck if you go to high a lift on the standard 5100s then you use them as you limit factor in droop. I am at roughly 3.5" or so lift in the rear so I would be at almost the max extension of the 5100s. I was informing the OP that there are different 5100s out there and essentially to get the correct ones for his amount of lift and application or he would end up with what you said bottoming out without much up travel. Just for reference a shock/suspension set up should have about 1/4-1/3 of the shocks tavel in up and 2/3-3/4 in droop, this isn't a hard and fast rule but just a good starting place. I wasn't telling the OP to use them my first sentence explains that.
  3. Jan 29, 2018 at 6:41 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    yep......correct P/N's
    5100's on the front using 3rd ring setting will raise nearly 2"
    purfect set up on my '14.......Amazon is not the best pricing
    Headstrong Off Road in Kalifornia is
    $340 all four shocks shipped
    ovrlndkull likes this.
  4. Jan 29, 2018 at 6:44 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    Lifted DCLB, sexyyyyy!
