Different approach to a snorkel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mach375, Mar 3, 2013.
  1. Sep 6, 2016 at 10:13 AM
    #201
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Drilling was maybe a 6-7 with the hole saw nearly rubbing on a bundle of wiring and next to a stack of hydraulics tubes. The real pucker was trying to dimple a center point with the ABS controller and its tree of pipes blocking the back swing to hit the punch, that might have been all the way to 11. After that, just make sure to start off with a small pilot hole (I did a 1/8" to start) then bump it up with a stepped bit till it'll take the guide bit for the hole saw, then when you go for the hole saw, it'll be locked into place which frees up a had for holding the wires out of the way.
    If I had another shot at it, I would have shifted it over about 3/16ths more toward the driver side. There's a hump in the sheet metal there and the spot where the center should have been is slanted and even my center punch was walking when I tried to dimple it (which doesn't bode well for the drilling to follow), so I settled for putting it at the edge of the flat.
  2. Sep 6, 2016 at 11:20 AM
    #202
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    When I drilled, I went as high as possible just in case a stream of water was to get in their. That way the hole would be higher than water level. I don't think it really makes a difference because I have seen several do it on the very bottom with no ill effects .
  3. Sep 6, 2016 at 11:42 AM
    #203
    bmgreene
    Brian
    L.A. Westside
    Vertically, I just tried to center it between the two wire bundles mounted along there. pulling the hole a little more toward the driver would probably have given me a hair more clearance to the ABS controller plumbing and made it a little less likely that something might flex into contact there.
    Only real issue I've had so far is an occasional rattle which is probably the aluminum air horn against the edge of the hole. I've gotta get some weather stripping or some kind of rubber or foam in there to pad that out; I've got some old rubber trim protector (made for the edges of the doors to protect against dinging other cars in parking lots) stashed away somewhere that'd do the trick if I can find it, otherwise I'll probably just put a ring of weather strip on the outside of the horn.
    findingthingsout likes this.
  4. Sep 15, 2016 at 10:46 AM
    #204
    bmgreene
    Brian
    L.A. Westside
    Now with a couple weeks of around-town driving, including freeways, I'm feeling like there's some increased throttle response from this, but that might just be my brain tricking the butt dyno into noticing somehting that may or may not be there. It does seem like at least getting rid of the "scooper" at the end of the stock intake should eliminate a pretty significant restriction since that thing had maybe a 2" opening at most, which is 1/4 the area of the 4" ducting leading to the air box.
    1rooster likes this.
  5. Sep 20, 2016 at 9:37 PM
    #205
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
    Part #s ?
  6. Sep 21, 2016 at 10:18 AM
    #206
    bmgreene
    Brian
    L.A. Westside
    Here's links to everything on Amazon:
    straight hose with clamps: this hose is 12" long, and I ended up cutting off about 3-4 inches, so if there's a 9 inch version, that might work better. I bought this one to simplify the order since it came with a pair of t-bolt clamps (these clamps are a different size nut that the others I used, and don't include ny-lock nuts like the others do if either of those might affect your choice)
    http://www.amazon.com/gp/product/B00KOBACJE
    hose elbow, 3" to 4" 90 degree: this is actually the elbow that's been at the bottom of this page for a while and doesn't come with any clamps.
    http://www.amazon.com/gp/product/B00GXJJEAE
    3" aluminum coupler to connect the hoses together:
    http://www.amazon.com/gp/product/B014GXP40W
    Here's the inlet horn I used, I ended up needing to put some weather strip around the perimeter of the hole in the truck to prevent metal-on-metal rubbing and a rattle coming from the glove box, there are also some plastic intake horns which would work as well or better out there and might not require any shielding around the hole in the panel. If I had left the aluminum horn rubbing on the steel edge, it did appear from just a week of wear that I would have eventually scraped a hole in the horn without some kind of protection.
    http://www.amazon.com/gp/product/B012T3QDII
    Here's the hose clamps I used, I may have gone overboard here sticking with stainless t-bolt clamps only, and the ny-lock nut on this is probably unnneccesary since I've never seen a clamp that uses one before, but I suppose it can't really hurt anything.
    http://www.amazon.com/gp/product/B0058W7X6E
    http://www.amazon.com/gp/product/B0058W7XYQ
    the "sock" I used ended up needing to be sewn shut at one end, so I'd recommend using a different item if you choose to use one. Here's the storefront for the supplier though, they have many options to choose from:
    http://www.amazon.com/s?marketplaceID=ATVPDKIKX0DE
    There are some less expnsive alternatives, and may be some better options out there, for me getting Prime shipping available was a factor in the selection of these parts. the whole kit cost me about $100 including tax and with free shipping, but depending on your membership and state of residence, some of that's subject to vary a bit.
  7. Sep 21, 2016 at 10:27 AM
    #207
    bigfella13
    bigfella13 Well-Known Member
    Nick
    Colorado
    4 banger 4x4
    Lift, armor and such. Money pit, check out the build thread...
    Sorry if I missed it, but has anyone done this on a 4 banger? Different airbox
    MSU Taco likes this.
  8. Sep 24, 2016 at 8:28 PM
    #208
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    Thanks! That metal coupler is what I was looking for.
    bmgreene[QUOTED] likes this.
  9. Sep 24, 2016 at 8:29 PM
    #209
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    I haven't seen anyone post a 4cyl. I'm sure it's very possible but I'd expect it'll be a few parts that are different
    bigfella13[QUOTED] likes this.
  10. Sep 25, 2016 at 9:09 AM
    #210
    bigfella13
    Nick
    Colorado
    4 banger 4x4
    Anything is possible with enough ducktape and will to get it done :D Maybe I'll give it a shot one of these days
    Wild Crow and MSU Taco[QUOTED] like this.
  11. Oct 8, 2016 at 7:17 PM
    #211
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
  12. Oct 8, 2016 at 7:54 PM
    #212
    Jeffvt0508
    Jeff
    Anderson, SC
    Any mpg increase/decrease from doing this?
  13. Oct 9, 2016 at 5:50 AM
    #213
    1rooster
    Georgia
    2007 Tundra crewmax
    I did not note any changes on fuelly.
    Jeffvt0508[QUOTED] likes this.
  14. Oct 9, 2016 at 4:41 PM
    #214
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Same. Just do it Jeff. Snorkels are soo last storm/flood.
    Bogg likes this.
  15. Oct 9, 2016 at 4:54 PM
    #215
    Jeffvt0508
    Jeff
    Anderson, SC
    Oh I'm planning on it.. I was just also hoping it increased mpg lol
  16. Oct 9, 2016 at 5:26 PM
    #216
    Sandman614
    Tim
    '06 SR5 Off Road
    A snorkel doesn't either.
  17. Oct 9, 2016 at 5:37 PM
    #217
    Jeffvt0508
    Jeff
    Anderson, SC
    I know.. was thinking about doin this mod but thought about an 90 down so if junk got into the cowl it would have a harder time
  18. Oct 9, 2016 at 8:17 PM
    #218
    bmgreene
    Brian
    L.A. Westside
    I'd you want to keep debris or of the intake, just put a sock or a prefilter ovet the pipe.
    I used a hydrobic cover, but any kind of nylon will work almost as well.
    Prefilters are made to keep water out, but that's rarely a problem for anyone.
    Sandman614 likes this.
  19. Oct 12, 2016 at 7:14 PM
    #219
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    TacoPandaTRD and Capt. Obvious like this.
  20. Oct 12, 2016 at 7:37 PM
    #220
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    What's a snorkel? :D
