different gearing? auto vs manual
Discussion in '4 Cylinder' started by tonykof, Jun 6, 2014.
  1. Jun 6, 2014 at 12:46 PM
    tonykof
    tonykof [OP] Member
    I have a stock 2014 reg cab manual 5 speed, my buddy has a stock 2013 reg cab auto. I understand they both have the same diff gears? (4:10s) If so is the final gear different in the two transmissions?
    we did a little experiment see below:
    His auto at 2000 rpms reads 62-63 on speedo
    My manual at 2000 rpms reads 54-55 on speedo
    note: they both have the same tires etc..
  2. Jun 6, 2014 at 6:36 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    I believe it's 3.31 for the manual & 3.58 for the automatic.
  3. Jun 6, 2014 at 8:11 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    On the 5 luggers, yes, but on the six lugs they're both 4.10.
    OP, that sounds about right, the overdrive on the auto is a fair bit taller.
    If you account for Toyota's intentional speedometer error, on the 5 speed with stock tires, 55 mph = 2150 rpm.
  4. Jun 6, 2014 at 9:31 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The manual has .81 overdrive while the automatic has .71.
    The difference in overdrive would be .71/.81 = .88 or 88% of speed at same rpm.
    Your auto at 62 mph times .88 = 55.6 mph with stick just like you found.
  5. Jun 7, 2014 at 10:31 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    So is this why these guys are saying the auto gets better fuel mileage.
    The auto has a taller final in the trans?
  6. Jun 7, 2014 at 6:04 PM
    worthywads
    Depends on speed, the stick is always at a fixed speed, the automatic will drop out of converter lock and maybe even drop into 3rd. In the right flat steady state conditions the auto can beat the stick, but depending how you want to drive the stick will do better. More often the stick will beat the auto with the I4.
  7. Jun 7, 2014 at 10:50 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    The EPA ratings for the 2012 regular cab 2 wheel drive Tacos bear that out:
    EPA city/highway fuel economy:
    21/25 (2WD, manual)
    19/24 (2WD, automatic)
  8. Jun 9, 2014 at 11:02 AM
    tonykof
    tonykof [OP] Member
    Now to add a question to my original...
    Both of these trucks are presently running stock 245/75/16. Using the tire size calculator. http://www.tacomaworld.com/forum/tirecalc.php?tires=245-75r16-285-75r16 in "theory" I should be able to run 285/75/16 & still be geared slightly lower than the automatic..?
    based at approx 2000 rpms
    manual with 245/75/16 = 55 mph (stock size)
    manual with 285/75/16 = 59.26 mph
    Auto with 245/75/16 = 62 mph (stock size)
    In reality I will most likely be running 265/75/16...
