different gears in rear diff, than the front
Discussion in 'Technical Chat' started by woodeye, Jul 12, 2024.
  1. Jul 12, 2024 at 4:33 PM
    woodeye
    woodeye [OP] Member
    Woody
    09 Tacoma
    4x4 Access cab
    i only have enough cash to replace the rear diff gears and do the front in about 2 monthsl
    what would happen?
  2. Jul 12, 2024 at 4:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Nothing, just don't put it 4wd.
  3. Jul 12, 2024 at 4:50 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Just wait the 2 months and do them at the same time that way if you change your mind you are not out any $$ and have a messed up Tacoma.
  4. Jul 12, 2024 at 4:53 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You'd gone full Ferrari. Never go full Ferrari.
    Joked aside, if you pull the front driveshaft, it would murphy-proof things until you regear the front.
    OldSchlPunk and ZColorado like this.
  5. Jul 13, 2024 at 4:36 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Just wait till you can do them both at the same time. Save and be patient. That way you will only have to do one break in period. If you can't control yourself, pull the front driveshaft so there is absolutely no chance of it engaging. No kids or dogs, or whacky old people putting it into 4wd by mistake.
    TartanEagle likes this.
  6. Jul 13, 2024 at 4:54 AM
    545 Well-Known Member
    2015 Access Cab
    Things will break if you put it into 4wd with different gears
    But in 2wd you won’t notice
  7. Jul 13, 2024 at 7:59 AM
    woodeye
    woodeye [OP] Member
    Woody
    09 Tacoma
    4x4 Access cab
    thanks for the advice, main reason i asked was because i went larger tires and tow
    a 3000 lb camper and notice a differance when towing. have some long trips set up
    for this month
  8. Jul 14, 2024 at 9:42 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    A friend had different gears in front and rear. Installed incorrectly by someone. When he put it in 4wd, it went crunch and grind. You know the rest.
