Different lug nuts for FJ wheels?
Discussion in 'Wheels & Tires' started by TacomaGRG, May 20, 2010.
  1. May 20, 2010 at 6:41 AM
    TacomaGRG
    TacomaGRG [OP] Well-Known Member
    Greg
    Danvers, MA
    09 SR5
    Westin Stainless Bull Bar Flowmaster 50 Dual Exhaust 17" FJ Cruiser Wheels Socks Devil Horn 3rd Brake Light Cover STK Pro Rack Carriage Works Black Billet Grille w/Devil Horns Stubby Antenna Avid Rocker Guards Rear Leaf TSB Rear Bilstein 5100s Front Bilstein 5100s @ 1.75 AFE Air Filter
    I just replaced my 16" stock steel wheels with FJ cruiser 17" aluminum wheels and my local tire shop said there wasn't much tread with FJ wheels and that I might need a different kind of lug nut. Any of you guys run into this? Do I need new lugs or are my stock ones fine?
  2. May 20, 2010 at 9:07 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I just had to get these as well. ~$135 for the anodized black ones from Toyota.
  3. May 20, 2010 at 9:59 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Thanks Guys! I need to get these. Do you think it will be save for a limited time to keep my stock lugs on there?
  4. May 20, 2010 at 10:06 AM
    Packman73
    2007 TRD Off Road
    Don't do it. It's not good for the wheels and likely not at all safe.
  5. May 20, 2010 at 10:17 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Thanks I'm going to try to pick them up from my toyota dealer in the morning. I guy I bought them from told me my stock lugs would be fine but I'm glad I checked with you guys. Thanks again!
  6. May 20, 2010 at 10:29 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Toyota told me $150. for the set. But I'm probably better off than going with cheap ones from an auto parts store right?
  7. May 20, 2010 at 10:49 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
  8. May 21, 2010 at 5:49 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    I have a 2001 Tacoma and I bought FJ Wheels. It came with the Lugs that were on the FJs. Are these ok to bolt on?
  9. May 21, 2010 at 7:39 PM
    Packman73
    2007 TRD Off Road
    As long as they look like the ones pictured above.
  10. May 21, 2010 at 7:40 PM
    YellowDog01
    04 4x4
    They look right. Same size and everything.
  11. May 21, 2010 at 7:41 PM
    Packman73
    2007 TRD Off Road
    You should be GTG.
  12. May 21, 2010 at 7:45 PM
    YellowDog01
    04 4x4
    Thanks man!
  13. May 23, 2010 at 6:45 PM
    Lunercrab
    Lunercrab Well-Known Member
    Beth
    Lehigh Valley area, PA
    2019 off road cement
    Are the lugs from the fj 16" different from the sport 17" lugs? I only ask cause I bought my fj rims they came with lugs but the tire shop reused my sports lugs claiming the fjs lugs were the same as the one I already had.
  14. May 23, 2010 at 7:25 PM
    Packman73
    2007 TRD Off Road
    I don't have a sport but I'm not so sure about that. Pull one off and see if it matches the pic above. If it's an acorn style, you may want to get those switched asap.
  15. May 23, 2010 at 7:50 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    stock sport lugs are like the ones above...at least mine were
  16. Jul 23, 2012 at 1:29 PM
    scmedic85
    scmedic85 Well-Known Member
    Greig
    Charleston, SC
    2012 DCSB 4WD
    I just ran into this issue. Sitting at the tire shop waiting on a guy from a local wheel shop to deliver new lugs.... Wish I had seen this first.
  17. Jul 23, 2012 at 2:42 PM
    scmedic85
    Greig
    Charleston, SC
    2012 DCSB 4WD
    Does anyone have a picture of what these look like? My shop could not find them, so these wheels are still sitting in my bed :(
  18. Jul 23, 2012 at 2:47 PM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I can't help with the 16" to 17" conversation, but the 17" Tacoma Sport wheels and the 17" FJ Wheels use exactly the same lug nuts.
  19. Jul 23, 2012 at 4:33 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    I believe the steel wheels use conical centering lug nuts and the aluminum are a straight shank lug.
    So there are not to be used on each other.
  20. Jul 23, 2012 at 5:23 PM
    scmedic85
    Greig
    Charleston, SC
    2012 DCSB 4WD
    Do the Tacoma Sport and FJ lugs look like this?
