Different size of tires
Discussion in 'New Members' started by yamilko76, Dec 19, 2024.
  1. Dec 19, 2024 at 11:33 AM
    yamilko76
    yamilko76 [OP] New Member
    My Tacoma is a 2018 TRD Sport. I want to change the tires, the factory size is 265/65R17 and I want to change them to 265/70R17 or 265/75R17 all-terrain tires, what do you advise me? It has 2 inch strut spacers.
    buckhuntin-tacoma likes this.
  2. Dec 19, 2024 at 11:35 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    265/70 will fit fine.
  3. Dec 19, 2024 at 11:35 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    265/70R17. Any bigger you start running chance of rubbing.
  4. Dec 19, 2024 at 11:43 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    265/75R17 is not a size. 265/70R17 will fit fine and will not rub on stock wheels. Potential starts with any larger tires or any aftermarket wheels on that size.
  5. Dec 19, 2024 at 12:06 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    yamilko76[OP] likes this.
  6. Dec 19, 2024 at 12:16 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I have a 2021 TRD Sport and researched a different way to lift the front of your truck.
    What I'm looking at is a Bilstein 5100 2" leveling kit...since the front is slightly lower than the rear.
    From what I've searched (and I've searched a lil bit), going 2" would be the max if wanting to stay within OEM limits. (The TRD Lift is another option but more expensive)
    Here's an opinion on tire sizes but not to be taken as gospel.
    https://www.trailbuiltoffroad.com/blogs/1333/what-tire-sizes-fit-best-on-a-third-generation-toyota-tacoma#:~:text=The largest tire for a,also clear without any issues.
    Use this calculator to see the difference in how the tire sits in the wheel-well.
    SecureIT2021 likes this.
