Different tow mirrors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Darkmatter, Jul 22, 2019.
  1. Jul 22, 2019 at 4:45 PM
    Darkmatter
    Darkmatter [OP] Active Member
  2. Jul 22, 2019 at 5:28 PM
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Too bad those don't have the BSM lights on them. If they did they could be full replacement even for us with Tech Package.
  3. Jul 22, 2019 at 7:33 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    Haven’t seen these before. I like the function.
  4. Jul 22, 2019 at 7:36 PM
    absolutgt
    absolutgt You know...here, there, and guardrails
    Georgia
    2016 MGM Double Cab
    FYI, those are the repro’s of the factory Tundra tow mirrors and if you do a search on google with tundra world and the repro’s they shake something fierce. I had a set on both my Tundra’s. First tundra were factory and good to go, second tundra I bought a set of repro’s and no matter how much you tightened they would rattle and the mirror motor is super finicky
  5. Jul 22, 2019 at 7:43 PM
    GeronimoCO
    GeronimoCO Active Member
    2016 TRD Off-Road Double Cab
    Those are nice but the stock mirrors are so much better looking.
    I tow a travel trailer several times a year so I got some of those extensions that fasten to the stock mirror with rubber straps. They work surprisingly well, they're inexpensive, and removable in less than a minute. May want to try those first if you're not towing on the daily.
  6. Jul 22, 2019 at 9:27 PM
    deusxanime
    MN
    Yeah I got these to tow with and they work very well (mount to bottom side of mirror) and, once set up properly, go on and off in a few seconds is all. Unless you are constantly towing and truly need those mirrors permanently mounted, I'd just stick with extensions of some kind.
  7. Jul 23, 2019 at 1:57 AM
    Darkmatter
    I don't tow that often. I had tow mirrors on a Silverado and loved how much more I could see.
  8. Jul 23, 2019 at 10:55 AM
    Inferno!
    El Dorado Hills
    I use the same extended mirrors. They work well, but they do shake a little.
