Different Wheel Setups on Stock Suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhiteTacoo, Oct 26, 2016.
  1. Oct 26, 2016 at 2:17 AM
    WhiteTacoo
    WhiteTacoo [OP] Member
    Evan
    Seattle, WA
    2015 Super White Tacoma TRD OR
    Post your wheel/ tire setups on stock suspension! For those like myself looking to get a new setup while putting off buying a suspension lift system in the farther future. For example: has anyone put 275s on an 18 inch wheel with 0 offset and 4.5" backspacing without rubbing?
  2. Oct 26, 2016 at 4:18 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Welcome to tacomaworld. :wave:
    Searching through this site, you'll find most all the info you'll ever need. :thumbsup:
    WhiteTacoo[OP] likes this.
  3. Oct 26, 2016 at 5:32 AM
    ChemDawg
    Maine
    2005 sr5 4x4
  4. Oct 26, 2016 at 5:40 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I had my procomps on before I did my suspension. They have 265-75-16 tires on them and the wheels have 0 offset. Because they have 0 offset the tires would rub when turning. I took them off until I installed my lift and then put the wheels back on.
  5. Oct 26, 2016 at 9:42 AM
    WhiteTacoo
    Evan
    Seattle, WA
    Thanks ChemDawg! Thanks for the link. If you don't mind me asking, what's your wheel/ tire setup? I'm asking because I dig your avatar pic
  6. Oct 26, 2016 at 9:45 AM
    WhiteTacoo
    Evan
    Seattle, WA
    Wow! So going from 265-70-16 (My stock wheel at least) to 265-75-16 and you were rubbing? Definitely will take that into consideration...
  7. Oct 26, 2016 at 9:47 AM
    moondeath
    Pa, Gardners
    Yeah, they rubbed because of the 0 offset. On a factory wheel those tires would fit fine.
  8. Oct 26, 2016 at 12:18 PM
    WhiteTacoo
    Evan
    Seattle, WA
    Do you know what the backspacing is on your wheel? Because a stock wheel I thought a 0 offset.
  9. Oct 26, 2016 at 12:19 PM
    moondeath
    Pa, Gardners
    Stock wheels have about + 27 to 30mm offset.
  10. Oct 26, 2016 at 12:20 PM
    moondeath
    Pa, Gardners
    Stock off-road and sport are +30mm and +32mm offset. I just checked.
  11. Oct 26, 2016 at 12:22 PM
    moondeath
    Pa, Gardners
    The less offset a wheel has the more it sticks out away from the frame. Another words less offset is like having a wheel spacer.
  12. Oct 26, 2016 at 2:32 PM
    WhiteTacoo
    Evan
    Seattle, WA
    Thanks for the info! By the way, love the look of your truck! Clean and simple yet subtly aggressive.
  13. Oct 26, 2016 at 5:32 PM
    ChemDawg
    Maine
    2005 sr5 4x4
    255 70 17 bs I think 4.5..
    general grabber at2s on xd hoss
