Differential Acuator Vacuum Hoses
Discussion in '1st Gen. Tacomas (1995-2004)' started by mkummet, Sep 21, 2010.
  1. Sep 21, 2010 at 9:52 AM
    mkummet [OP] New Member
    Sep 21, 2010
    Recently bought a '04 Tacoma, and suddenly the 4 wheel drive is not working. The transfer case seems to be working fine (it gears down when I shift into 4low). I suspect that is the A.D.D. that is malfunctioning.
    I followed the vacuum lines from and to the actuator and found that both lines are caped off. Does anyone know where these lines are supposed to go or if there are other actuators that people install to replace the OEM?
    Thanks in advance
