differential and manual tranny oil?
Discussion in 'New Members' started by funhoggrace, Feb 2, 2022.
  1. Feb 2, 2022 at 1:00 PM
    funhoggrace
    funhoggrace [OP] New Member
    william
    2003 tacoma 2.4litre engine 2 wheel drive
    should i use toyota 's oil for oil change?
  2. Feb 2, 2022 at 1:01 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Toyota's fluid is just fine unless you need something different or aren't happy with it.
    That said, I'll likely be swapping in Redline fluids when the time comes.
    Funch likes this.
  3. Feb 2, 2022 at 1:49 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Black DOG Lila likes this.
  4. Feb 2, 2022 at 1:51 PM
    Funch
    Funch Well-Known Member
    I hear good things about this redline oil, but I also heard that you should use regular oil instead of synthetic for differentials. What are your thoughts?
  5. Feb 2, 2022 at 3:27 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  6. Feb 3, 2022 at 7:19 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Ehhh, I think that's an old way of thinking. There's still guys that change their oil every 3k regardless of when it actually breaks down or gets dirty. There's no reason you should need a conventional fluid pretty much at all anymore as (good) synthetics use higher quality materials and are literally engineered to be better. So long as you get the right synthetic fluid for your application it should lube better and last longer (still change at factory intervals or do independent testing to see when it actually needs changing - don't just run it forever).
    If you're that worried about it though just stick to the factory stuff. Don't just take my opinion on it, do some research for these specific diff's and compare the factory fluid specs vs multiple synthetic options to see what is right for you. Nothing worse than changing something and then being paranoid about it for the next 30k miles.
    Funch likes this.
