Differential and Transfer Case Fluids
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cappy, Feb 28, 2021.
  1. Feb 28, 2021 at 11:43 AM
    Cappy
    Cappy [OP] Well-Known Member
    Georgia
    I'm planning on changing out my fluids and I'm a little perplexed about what would be a good choice for my 2017 Sport 4X4. I've been searching and it looks like any top brand of 75W-90 is a good choice (Toyota recommends 75W-85) but also read that the sport model requires a limited slip additive but I'm not sure that applies to the 3rd gen or just 1st or 2nd gens. Also not sure if the same fluid is used for the transfer case and front/rear differential. Dumb question I know but want to make sure I get the right oil. Thanks
  2. Feb 28, 2021 at 11:45 AM
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    amsoil for diffs redline for t case
  3. Feb 28, 2021 at 11:47 AM
    Cappy
    Georgia
    I've read that those are a good choice but it's the weight and LS additive that I am most concerned about. Thanks
    98_3RZ_NIC[QUOTED] likes this.
  4. Feb 28, 2021 at 11:48 AM
    Bishop84
    Bishop84 Well-Known Member
    Only 2nd gen early models had LSD addtives required, your truck only need GL5 75W85 or 75W90. (auto LSD is electric traction aid, not a real lsd)
    I personally just use cheap oil on my diffs and change it more frequently.
    Make sure to pick up gaskets for the drain plugs from a dealer first.
  5. Feb 28, 2021 at 11:52 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    This stuff on the TC.
    https://www.redlineoil.com/mt-lv-70w75w
    For the diffs, any good quality 75/90 will work.
  6. Feb 28, 2021 at 12:00 PM
    Cappy
    Georgia
    Good info. Thanks guys
  7. Feb 28, 2021 at 12:08 PM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I personally have been using Amsoil in just about everything / every vehicle I've owned over the last 20+ years. A Ford F250 diesel, a 2001 Dodge Cummins (both 4x4s), a Harley-Davidson Sportster, and now my Tacoma. Only exception being that I am still running on the original factory lube in the transfer case... I haven't yet changed it out. I did both diffs and 6 speed trans at around 4K miles, with various Amsoil lubes, just not the transfer case. I'll do that this summer, might use the Redline for that, as it seems a popular choice among TW forum members, and I have read other threads here that Redline more closely matches the OEM stats than Amsoil does for the transfer case.
  8. Feb 28, 2021 at 12:28 PM
    Cappy
    Georgia
  9. Feb 28, 2021 at 12:34 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The 3rd gen T-case needs special low-viscosity fluid. Use either Redline MT-LV or the Toyota unicorn tears from the dealer at $50 a can, or you'll have problems shifting into 4WD, especially on cold days.
    Speedbird likes this.
  10. Feb 28, 2021 at 12:41 PM
    Cappy
    Georgia
    Thanks. Looks like redline for me then. I just didn't know if the MT on the redline bottle meant it was just for a manual transmission or was good for both since mine is an automatic.
  11. Feb 28, 2021 at 12:51 PM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
  12. Feb 28, 2021 at 12:57 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    How many miles you got? I changed em all at 30k on my taco and the transfer case fluid still looked new.
    Ravenol worked well for my t-case
    FantasyFreak likes this.
  13. Feb 28, 2021 at 1:01 PM
    Cappy
    Georgia
  14. Feb 28, 2021 at 1:02 PM
    Cappy
    Georgia
    Just turned over 38,000 this past week so plan on doing it soon. Thx
  15. Feb 28, 2021 at 1:11 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I switched to Lucas dinosaur squeezings. I change F&R dif and transfer case oil every 30k. Synthetic has gotten expensive.
  16. Feb 28, 2021 at 1:32 PM
    FantasyFreak
    FantasyFreak Well-Known Member
    Fort Worth
    No Mo Taco/ Upsized
    I went with Ravenol for diffs and T-case. Happy so far and really don’t see a difference but I’m just a normal driver for now.
  17. Feb 28, 2021 at 1:56 PM
    SRBenjamin
    Benny
    Transfer case, not Transmission.
  18. Feb 28, 2021 at 2:17 PM
    Cappy
    Georgia
    Gotcha. I just wasn't sure if it was different transfer case oil depending on the transmission type. I've never changed that before. Thanks.
