Differential and transfer case oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mallard386, Jul 24, 2019.
  1. Jul 24, 2019 at 4:47 PM
    Mallard386
    Mallard386 [OP] Well-Known Member
    Virginia
    2001 ext cab 4x4 4 banger 115k and counting
    TBD
    looking for recommendations on what brand oil y’all like for both your differential and transfer case. I’m looking at changing both this weekend. Also how hard of a project is this for someone who’s not exactly a wrench turning type. Thanks in advance
  2. Jul 24, 2019 at 4:50 PM
    eon_blue
    Azusa, CA
    75w90 gear oil, super easy process. There's a drain plug and fill plug on the diffs and t-case. Replacing the crush washers on each of them is smart to do, you can pick those up from the dealer (or online).
    Always loosen the fill plug first, you don't want to drain it and then realize the fill plug is stuck on or stripped.
    The front diff uses a hex/allen key rather than a normal socket like the t-case and rear diff, make sure you clean the dirt out of the hex before you try loosening them or they will strip on you. Speaking from experience
  3. Jul 24, 2019 at 4:52 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Boom. What he said ^
    koditten likes this.
  4. Jul 24, 2019 at 4:58 PM
    Mallard386
    Virginia
    TBD
    Awesome thank you this will be very helpful! Stupid question tho... use the 75w90 in both the t case and the diffs?
  5. Jul 24, 2019 at 4:59 PM
    Mallard386
    Virginia
    TBD
    Thank you good sir! Any brand preference or just the super tech that Walmart sells?
  6. Jul 24, 2019 at 5:53 PM
    eon_blue
    Azusa, CA
    Any regular gear oil will do, just don't use synthetic in the diffs. Regular stuff is better for them.
    The manual transmission (if you have one) is where it pays to use the good (expensive) stuff
  7. Jul 24, 2019 at 5:54 PM
    Mallard386
    Virginia
    TBD
    Cool beans. Sadly it’s an automatic so I guess I’ll just have to see what’s on sale!
  8. Jul 24, 2019 at 5:59 PM
    eon_blue
    Azusa, CA
    Everyone's got different preferences on brands but honestly if you change it at the regular suggested intervals it really shouldn't matter.
    Only time you might want to change up the type of gear oil is if you do a lot of towing, wheeling, extreme cold weather, etc. Otherwise just go by the book
  9. Jul 25, 2019 at 6:53 AM
    Mallard386
    Virginia
    TBD
    Next stupid question.... Why not synthetic?
  10. Jul 25, 2019 at 9:29 AM
    eon_blue
    Azusa, CA
    East Coast Gear Supply and other manufacturers all suggest regular dino oil over synthetic, the regular stuff does a better job of not thinning out when it gets really hot like synthetic does. Also regular gear oil separates water from the oil better than synthetic does.
    Here's one article on it
    https://eastcoastgearsupply.com/ft-2536-ecgs-gear-oil-recommendation.html
  11. Jul 25, 2019 at 10:48 AM
    Mallard386
    Virginia
    TBD
    Are you talking about transmission fluid now? Or still gear oil?
  12. Jul 25, 2019 at 10:49 AM
    eon_blue
    Azusa, CA
    He's talking about auto trans fluid
  13. Jul 25, 2019 at 10:49 AM
    Mallard386
    Virginia
    TBD
    Awesome thanks for the article I’ll check it out!
  14. Jul 25, 2019 at 10:50 AM
    eon_blue
    Azusa, CA
    That's really just pertaining to gear oil, when it comes to engine oil I think synthetic is the way to go personally. I switched to that awhile ago
    Running Board Man likes this.
  15. Jul 25, 2019 at 1:41 PM
    Mallard386
    Virginia
    TBD
    I always have and always will run synthetic motor oil. Stay posted for all my attempts at doing all this for this weekend. Going to do the diffs, the t case, motor oil , trans fluid and change all my belts and hoses and lastly plugs and wires if it needs it. I just bought the truck and it had 115k so I figured why not do some basic things! Anything else I should do?
  16. Jul 25, 2019 at 7:40 PM
    1997tacomav6
    Denver
    I use redline or Amsoil.
    vettehigh and Running Board Man like this.
  17. Aug 2, 2019 at 7:19 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I was given a free case of valvoline 80w90 gear oil.... would I harm my rebuilt trans by using that instead of 75w90?
  18. Aug 2, 2019 at 8:23 AM
    Mallard386
    Virginia
    TBD
    Nope! Thats what I ended up putting in mine. As mentioned because walmart sells in the gallon jugs
  19. Aug 2, 2019 at 8:25 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    I highly recommend Redline MT90 in the 5 speed.
    CS_AR and Running Board Man like this.
  20. Aug 2, 2019 at 8:37 AM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    I have been using AMSOIL Severe Gear 75w140 in my E-locker since day one. My experience is the diff runs 10 degrees cooler than 75w90 and the magnetic drain plug has much less particulates with the 75w140.
    Personally I think Lucas oils are marketing company, not a cutting edge oil company. I have yet to read a white paper on any Lucas product that performed well. Usually near the bottom.
    Here is an interesting read.
    https://www.lastgreatroadtrip.com/wp-content/uploads/2010/11/gear-oil-comparison.pdf
    OneWheelPeel likes this.
