Differential and Transmission oil change questions
Discussion in 'Technical Chat' started by usnatclee, Oct 11, 2009.
  1. Oct 11, 2009 at 9:17 PM
    usnatclee
    usnatclee [OP] Well-Known Member
    Clark
    Corpus Christi, TX
    13 corvette 12 Camaro 13 And Wrangler
    (SOLD)4 Bilstein 5100's, OME885s, 2" Toytec AAL rear, 3" total lift, 285/70/R17 BFG MTX on stock rims, AIRAID cold air intake w/ secondary filter removed, CB radio w/ firestik shorty antenna, custom bumper and sliders from those guys rod and customs, URD stage 3 competition clutch, Tom Woods one piece double cardan drive shaft, and URD short throw shifter.
    I have a 06 Tacoma TRD Sport 4.0. I replaced my rear diff oil today no problem. I am not sure how to do the front though and also unsure about how to do the transmission oil. Can someone post pics or a diagram of how to do this. Thanks in advance.
  2. Oct 11, 2009 at 9:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I belive the front diff requires a 10mm hex wrench. Preferably a socket. Halfway up, you should see the fill plug trward the rear of the driver side front axel. The drain plug will be on the bottom.
    For the manual tranny, the fill plug is on the driver side, about halfway up the side. I think its a 22mm.....
  3. Oct 11, 2009 at 9:28 PM
    usnatclee
    Clark
    Corpus Christi, TX
    Yeah it is a 6spd manual
  4. Oct 11, 2009 at 9:28 PM
    usnatclee
    Clark
    Corpus Christi, TX
    Does the front diff run the same oil as the rear diff?
  5. Oct 11, 2009 at 9:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. They all can run the same oil
  6. Oct 11, 2009 at 9:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    WHOA!! Wait....I didnt notice you had the Sport. Use 4 to 8 ozs of LS diff addative in the oil for the rear.
  7. Oct 11, 2009 at 9:32 PM
    usnatclee
    Clark
    Corpus Christi, TX
    yeah I followed that write up on the rear diff oil and I put the additive in it. Just didnt see anything for the rear.
