Differential Assembly Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by catskill.joe, Aug 29, 2022.
  1. Aug 29, 2022 at 10:10 AM
    catskill.joe
    catskill.joe [OP] Well-Known Member
    04 Red TRD Off Road - XtraCab - 6 cyl - Manual
  2. Aug 29, 2022 at 11:39 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Without seeing things in person.
    When the pinion bearing failed it took out both the pinion and ring gear ? Was this not making lots of noise??
    Go with East Coast Gear built differential !! Check on the core charge ! Most likely the cheaper option in the long run!!
    Rather then repairing yours with all the labor time !! Good Luck!!
    Will a new ring gear and pinion plus the bearing fix things?
    Area51Runner likes this.
  3. Aug 29, 2022 at 11:47 AM
    catskill.joe
    I'm going up to the shop to talk to the owner in a few minutes but from what we talked about on the phone...
    He said the teeth of the diff were really worn - as if it had been heated up and driven on. Perhaps with low fluid. When the truck was making the noise, I drove it about 15 to 20 miles - he didn't think that driving would do the damage he is seeing.
    His suggestion was to just replace the entire diff and not rebuild. The said labor for rebuilding would be 2k+ and not worth it. So, I was thinking to just replace it with something from East Coast Gear.
    I'll look into the Core Charge. Does that program mean they send me a rebuilt and I send them my old one?
    I think the diff is toast in addition to these two. And I need both wheel bearings replaced. So...I think the whole diff assembly is the way to roll.
  4. Aug 29, 2022 at 11:54 AM
    Bivouac
    In most cases that is what happens it depends if your differential meets East Coast Gears core specs !!
    If not your also buying the core which could run a few hundred.
    Then you also might have a build time wait .
    I would call and talk on the phone.
    Good luck!!
  5. Aug 29, 2022 at 12:08 PM
    catskill.joe
    Much obliged @Bivouac
    I'll give them a call. I'm curious what the gear ratio is. Looks like the core deposit is $950. Makes the total 1.7k. Thats spicy
  6. Aug 29, 2022 at 12:46 PM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    OP,
    OP,
    You said you have a E-locker diff. The Toyota diff. you linked is the more common NON E-locker diff. This looks to be the more expensive E-locker diff. but verify it is correct for your VIN: 1996-2004 Toyota Tacoma Carrier Assembly 41110-35861 | LaGrange Toyota
    ECGS can do an exchange on your diff. I am currently doing an exchange with them on the front 7.5" clamshell diff. for my '97 Taco. They had a time slot open up so ECGS built the clamshell and had it to me in just 4 days. Check with ECGS on current lead time & core charge. If I needed a rear diff. for my Taco, it would be from ECGS and not Toyota. Best of luck!
  7. Aug 29, 2022 at 1:13 PM
    catskill.joe
    Thanks for catching my error, for the link and for endorsing ECGS. I was just about to head to the shop with the wrong printout in tow. It seems ECGS is the way to go. I'll give them a call about lead times
    Wulf and leid[QUOTED] like this.
  8. Aug 29, 2022 at 1:28 PM
    leid
    Brandon, MS
    Happy to help. ECGS core policy on E-locker is below: Core Policies (eastcoastgearsupply.com)
    CORE CHARGE:
    Your cores must be in transit back to East Coast Gear Supply within 30 Days of receipt of new differential or you will be charged a restock fee.
    Restock Schedule: • 45 Days 15% • 90 Days 30% • 120 Days + 50%
    E-locker Differentials
    • Carrier Assemblies must be in usable condition (no excessive rust, broken, spun bearings, excessive runout, etc)
    • Spider Gears must be in usable condition (not broken, stripped out, etc)
    • Differential Housings must be in usable condition (no excessive rust, broken, etc)
    • Damaged Ring & Pinions or Bearings are of no consequence
    T8.75 E-locker cores must be returned with the plunger guard attached
    Bivouac and catskill.joe[OP] like this.
  9. Aug 29, 2022 at 1:31 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    story makes sense to me...Pinion bearing failure can happen if fluid is low enough that oiling is insufficient. When the pinion bearing fails the contact pattern can change and accelerate wear of the ring and pinion if not total eventual failure. Not to mention the metal particulates from the pinion bearing cage likely getting munched by the gears.
    I caught a pinion failure earlier this year and a golf ball size clump of metallic glitter was in the oil when I drained it.
    ECGS is good to go for rebuilt thirds, I'm running several from them without issue. Their phone service is great as well.
  10. Aug 29, 2022 at 2:17 PM
    Bivouac
    Your core could go either way Good luck!!
  11. Aug 29, 2022 at 2:32 PM
    catskill.joe
    Definitely going ECGS. Just gotta get an idea on lead time and avail for what I need
    Bivouac likes this.
