differential bearing help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ccal, Feb 23, 2017.
  1. Feb 23, 2017 at 4:48 PM
    ccal
    ccal [OP] Well-Known Member
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    does anyone know how long is ok to drive the truck with the bearing making noise? my truck is a 2014 has 15000 miles on it. also my truck has 5100s set at 1.75 on the front with a snowplow undercarriage attached do you think the dealer will do the bearing under warranty? or try to blame it on the minor lift or the plow setup?
  2. Feb 23, 2017 at 4:50 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    The plow itself will probably void the warranty, but not sure on that, and there is a TSB for the needle bearing
