Differential Breather Mod for Dummies (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Oct 2, 2008.
  1. Apr 7, 2012 at 7:16 PM
    #341
    2012TRDSport
    2012TRDSport Well-Known Member
    Geoff
    Anchorage, AK
    2012 TRD Sport DC 4X4
    Plasti-dipped front emblem, debadged, wet okole seat covers, tailgate lock mod, anytime fogs, yellow wire mod, BHLM
    Thanks for the great write up, just took care of this mod.
  2. May 4, 2012 at 10:49 AM
    #342
    montes6173
    montes6173 Any place is comfortable if you make it that way
    Christopher
    El Paso, TX
    05 Tacoma TRD Off-Road
    Black Western Bull Bar, Avid Off-Road Side Steps, Truxedo Tonneau Covers(OFF), Painted Badges and Grill Black, Removed Mud Flaps, Bestop Supertop(ON), Diff breather mod, plastic-dip lower valance and rear bumper.
    Just a quick question, might be dumb but does it have to be a fuel Line or just any type?
  3. May 4, 2012 at 11:38 AM
    #343
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    the diff gets pretty warm, the air will be pretty warm, add the fact that it will be under the truck for a long period of time and will be getting hit by rocks, mud, and what not, You're going to want a pretty sturdy tubing. I wouldn't cheap out on it. Just spend the extra couple bucks and get the good hose.
  4. May 4, 2012 at 11:46 AM
    #344
    montes6173
    Christopher
    El Paso, TX
    Cool thanks.
  5. Aug 2, 2012 at 3:52 PM
    #345
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Did this mod today on my 2011 4x4 4cyl manual transmission. While I was under the truck i looked for the transmission breather and found a one way breather, like the rear diff had, on top of the transmission next to the shifter on the engine side. It's tucked right up in there couldn't see it, might be able to get a picture.
    I gave it a thorough groping, and couldn't feel anything for a wrench to turn it. Seems like it's pressed in. Couldn't find the transfer case breather? Was wondering if anyone with a four cylinder 4x4 manual could give any insight? I'll try to get some pictures.
    Here are some pictures. Really hard to get good ones. Had to stuff my welding mirror up there. The first picture got my finger on it you can't see the breather, but it gives a better idea of where it is. The next few show the little cap on it. It moves up and down like the old rear diff breather, and I'm pretty sure it's pressed in.
    Anybody have a how-to on getting to the top of transmission from where the shifter comes down in? Be able to get some better pictures this way maybe.
    Here is the second picture again.
  6. Sep 23, 2012 at 9:31 PM
    #346
    juststu
    juststu Member
    Stuart
    Vancouver B.C.
    White 2006 Toyata Tacoma
    Adjustable 5100 series bilstein shocks(adjusted to 2.5" in the front), Front diff drop, OME Dakar leaf springs (approx. 2.75" lift), Rear diff breather mod, L.E.D. lit 4WD switch, Safari snorkel and CBI Off Road Fab Moab 2.0 front bumper.
    Thanks for putting in time with all the pics! The parts numbers worked out perfectly too. Had to oil up that Camry union to get the gas line on it. other than that it was a breeze. I'm new to this site and this was my first mod. now I've just got the itch to do more!
  7. Sep 28, 2012 at 9:14 PM
    #347
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    will try this tomorrow.. i noticed there are two different unions being used.. the OP uses a black one and another member use a polished looking one. is the black union plasctic and the other metal?? if so i need/want to order the polished metal one instead? please help..
  8. Sep 28, 2012 at 11:41 PM
    #348
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    These are the front dif and transfer case breathers?
  9. Sep 29, 2012 at 12:53 AM
    #349
    TACOconvert2012
    Socal
    never ending..
    Yes
  10. Sep 29, 2012 at 6:35 AM
    #350
    MikeCB600F
    Plainfield, IL.
    Thanks for the info. I saw one of the pics in the thread refer to these two breathers as the front dif and ADD. I could not figure out what ADD was.
  11. Sep 29, 2012 at 2:50 PM
    #351
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    black one is metal.
  12. Sep 30, 2012 at 11:58 AM
    #352
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I just did the breather mod but added my own spin to it.
    The company I work for allows me access to all sorts of cool stuff, I could have gone the easy route using the Toyota OEM parts #90404-51026 Camry union and 90930-03136 breather union but decided to try a different approach.
    From my work I bought a 1/8" BSPT 1/4" brass hose barb (not pictured), this threads into the rear differential, this is the same thread pitch as the Toyota OEM breather. I also picked up a brass bulk head fitting, 90 degree elbow and a breather vent.
    bulk head fitting, vent and 90 deg elbow, I had already installed the BSPT hose adapter when I decided to take the picture.
    I decided on the large cubby for the mounting location, I drilled a 3/4" hole and installed the bulk head fitting, vent and elbow.
    I installed the hose and ran along the top of the frame leaving enough slack for rear end travel. I like how clean it looks.
    I also picked up some slotted t-nuts a couple of vinyl coated J hooks and mounted my shovel.
    I used Velcro straps to hold the shovel in place.
    Parts list from McMaster-Carr Supply.
    For the breather mod
    1075T71 BSPT hose barb
    5454k86 bulk head fitting
    53525k11 90 degree elbow
    9833k21 vent
    5288k114 hose
    For the shovel mount
    90526a592 slotted t-nuts
    1730a91 J hook
    92323a551 3/8-16 serrated flange cap screws.
  13. Oct 11, 2012 at 4:59 PM
    #353
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
  14. Oct 15, 2012 at 8:51 PM
    #354
    turbo325ii
    turbo325ii Active Member
    Brett
    Provo
    06' Double Cab TRD off road
    none
    Did this mod. Sweet as candy! And I hope they fired the DERP from TRD that was in charge of the rear diff breather... :( FACEPALM
  15. Nov 9, 2012 at 4:01 PM
    #355
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    sub' doing this soon, thank you for the info and pics :)
  16. Nov 10, 2012 at 2:00 PM
    #356
    jeratbp
    jeratbp Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
    I did this mod this morning. Thank you vy much for the write up and the pics.
    I bought 6 foot of the 1/4 inch fuel tube, and probably cut about 6 inches off. I zip tied what I could while still having room to move.
  17. Jan 21, 2013 at 7:02 AM
    #357
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    toyota camry union
  18. Jan 24, 2013 at 12:13 PM
    #358
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    Just wondering, why is this mod necessary?!! :anonymous:
    Rookie modder here :canada:
    angeldavid216 likes this.
  19. Jan 24, 2013 at 12:17 PM
    #359
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    so that you dont suck water into your rear diff when you cross water thats deeper than your axle.
  20. Jan 24, 2013 at 12:23 PM
    #360
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    Did this mod. Great write up!
    The stupid union fitting and breather cost $20+ at the dealer :eek:
    Oh well, if it will keep water out of my diff.... Totally worth it :D
