Differential Breather Mod for Dummies (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Oct 2, 2008.
  1. Sep 12, 2014 at 7:24 PM
    #561
    skygear
    skygear                    
    I love that everyone is using my taillight location! Innovate!
    angeldavid216 likes this.
  2. Sep 12, 2014 at 7:50 PM
    #562
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Thank you for the idea :cool:
  3. Sep 13, 2014 at 4:12 AM
    #563
    4byota
    4byota Member
    Upstate NY
    2010 Bone Stock V6 MGM Access AT 4x4
    Earlier this summer I was dropping off scrap metal at the recyclers during the end of a heavy rainstorm. A flash flood had occurred and I drove through the aftermath. The deepest parts came up to the bottom of my doors. Wonder if I should inspect things?
  4. Sep 13, 2014 at 7:46 AM
    #564
    AR15xAR10
    It would not be a bad idea bud....at least the rear end
  5. Sep 13, 2014 at 10:22 AM
    #565
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    If everyone would do this (most simple) mod, you wouldn't need to wonder if your fluid is contaminated. It will be milky if it is.
    I have my own set of photos and a thread on how I did the mod... in my sig.
  6. Sep 16, 2014 at 4:57 AM
    #566
    yotastaco
    yotastaco Well-Known Member
    VA
    2015 MGM TRD OR
    See Build
    What's everyone's say on adding a filter (fuel etc) at the end of the breather line?
  7. Sep 16, 2014 at 5:20 AM
    #567
    AR15xAR10
    An open filter like a little k&n or something is more seceptable to getting wet....if you use the part numbers that the OP recommended, you shouldn't have to worry about water intrusion. Plus, the toyota breather would take up less space...
    It really is up to you :)
  8. Sep 16, 2014 at 1:23 PM
    #568
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
  9. Oct 21, 2014 at 4:27 PM
    #569
    PeterVICEG
    PeterVICEG Well-Known Member
    An old thread but still relevant. I have a three week old access cab TRD off road and when I crawled under to have a look, sure enough the rear diff has the breather mounted on it.
    I do not need to be conviced of the need to move the vent up as I have done this on a series of trucks. I do have a clarifying question though.
    I found the two remote vents in the engine compartment and see in this thread that they come from the transfer case and some other gizmo.
    Am I correct in assuming that there is a need for a remote vent on a front diff that must be buried in there?
    Thanks,
    Peter
  10. Oct 21, 2014 at 6:26 PM
    #570
    yotastaco
    VA
    2015 MGM TRD OR
    See Build
    Front diff is vented up to the top of the engine already. Do this mod and go behind the driver's side tail light.
  11. Nov 12, 2014 at 4:24 PM
    #571
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
  12. Nov 14, 2014 at 4:20 AM
    #572
    gen2tegboi
    gen2tegboi Well-Known Member
    Juan
    Florida
    98 Tacoma Ext Cab SR5 2.4L
    Dumb question, so let's say about a year ago I got stuck in water for about an hour while I waited for someone to pull me out. I do not have this mod, so what now?
    Change the rear diff fluid? Any damage seeing it was a year ago?
    Freaking out..
  13. Nov 14, 2014 at 4:27 AM
    #573
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Check and see / change fluid anyway. Then do mod............
  14. Nov 14, 2014 at 7:00 AM
    #574
    gen2tegboi
    Juan
    Florida
    Truck is a 2013 still under warranty. Can I still do it myself? Or will I be voiding the warranty by changing fluid myself? Btw truck has 20k miles.
  15. Nov 25, 2014 at 11:49 AM
    #575
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Do they sell this as a complete kit? And do you still do it through the pop out in the bed?
  16. Nov 25, 2014 at 1:08 PM
    #576
    Square
    Square Well-Known Member
    Brian
    Mission Viejo, CA
    '14 DCSB SR5 4WD MGM
    No kits. Just a couple of easy to source parts. You don't have to go through the bed, you can come up behind the taillight.
  17. Nov 25, 2014 at 1:24 PM
    #577
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Can you possibly post links to all parts needed?
  18. Nov 25, 2014 at 1:27 PM
    #578
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    Haven't checked out this thread for some time. Is the point of mounting behind the tail lights to get the breather cap higher? You could have mounted that several inches higher.
    Eyeballing it on my truck the end of your hose is no higher than mine in the gas filler area. Since mine is forward of the rear axle, couldn't yours actually end up lower than mine -driving up angle out of water?
    Edit: After thinking about it I guess that is just an easier location to do the work. I did it years ago but I do remember what a PITA it was working with one hand behind my fender. ;) If you have water high enough to reach either location -you have bigger problems to worry about!
  19. Nov 25, 2014 at 1:32 PM
    #579
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    How is it supposed to breath air behind something though?
  20. Nov 25, 2014 at 3:55 PM
    #580
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    See the first post in the thread
    It's behind something but not in a sealed compartment
