Differential Breather Mod for Dummies (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Oct 2, 2008.
  1. Dec 17, 2017 at 8:54 PM
    #901
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Post some pics
  2. Jan 2, 2018 at 6:15 AM
    #902
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Subbed. Will be doing this mod in the next week. Thanks for posting up the part numbers needed for this OP! Great write up
  3. Jan 2, 2018 at 9:04 AM
    #903
    AZeyeTIE
    AZeyeTIE Uh huh
    Dewey, AZ
    '14 Super White TRD Baja
    Nothing noteworthy
  4. Feb 12, 2018 at 4:39 PM
    #904
    bangin4WV
    bangin4WV Well-Known Member
    Rocky
    WV.
    2016 SR5 2.7 MGM ACLB
    33s/sliders
    Do you know if these parts will work for the 3rd Gens?
  5. Feb 12, 2018 at 6:16 PM
    #905
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Biscuits, okichewy1 and nateshrum like this.
  6. Feb 13, 2018 at 9:40 AM
    #906
    nateshrum
    nateshrum Well-Known Member
    Nate
    Boise, ID
    2005 Tacoma
  7. Feb 13, 2018 at 12:44 PM
    #907
    bangin4WV
    Rocky
    WV.
    33s/sliders
    gulzeb and Boyk1182[QUOTED] like this.
  8. Feb 13, 2018 at 4:19 PM
    #908
    euroshowoff
    euroshowoff Well-Known Member
    Stafford, VA
    15 Superwhite DCSB 4x4 V6
    Toytec lift, Trailgear sliders, CBI ditch light brackets, Trailtoys LED ditch lights, Trailtoys LED reverse pods, Custom Roll-Bar, TRD skid plate, TRD sport grill, TRD custom bedsides, Custom BlueSea wiring block, OTTRAW Rockers, Pro Comp 7036, BFGoodrich KO2s, Bestop soft topper,VIAIR 88p
    Boyk1182[QUOTED] likes this.
  9. Feb 13, 2018 at 4:22 PM
    #909
    Tootall604
    Tootall604 Well-Known Member
    2015 Tacoma sb
    Sub for future mod
  10. Feb 13, 2018 at 4:56 PM
    #910
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
  11. Feb 13, 2018 at 5:00 PM
    #911
    Boyk1182
    Northern Colorado
    The parts are good, same things you’d get at the dealer. The kit is like a $5 convenience fee to make it easier.
    gulzeb[QUOTED] likes this.
  12. Feb 16, 2018 at 8:10 PM
    #912
    euroshowoff
    Stafford, VA
    Should I be using worm clamps, or the hose slipped over the fitting strong enough?
    gulzeb likes this.
  13. Feb 16, 2018 at 8:10 PM
    #913
    Boyk1182
    Northern Colorado
    I used hose clamps.
    gulzeb likes this.
  14. Apr 6, 2018 at 2:33 PM
    #914
    PMfeelsnopain
    PMfeelsnopain Well-Known Member
    Stefan
    NOR✯CAL - SF East Bay - Concord
    2015 TRD Sport DCSB 4.0 V6 4x4
    Sweet ass bug deflector
    Great write up. I went with a can of Copenhagen instead of Skoal but it still came out perfect.
    TheDevilYouLove likes this.
  15. Apr 6, 2018 at 3:15 PM
    #915
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    20 ft of hose(gonna do fronts too) off Amazon, Camry union, and hose clamps. I reused the breather out of the diff, fits 1/4 id hose perfectly. Zip tied to the fuel filler, not drilled though.
  16. Apr 6, 2018 at 3:42 PM
    #916
    Boyk1182
    Northern Colorado
    I think a big benefit is that you change the breather to a 2-way breather. If you reuse the one on the diff, you still have a 1-way breather. So if you then go through cold water with a hot axle, it is going to try to suck air in. The 1-way breather won’t allow that (it lets air out only), and you get water sucked in through the seals. It will be the same problem, just now it’s higher, but doesn’t solve the problem.
    Also, isn’t the front already a 2-way and located at the top of the engine bay? Mine is (2014) so it’s ideal already.
    Hartford and gulzeb like this.
  17. Apr 6, 2018 at 3:48 PM
    #917
    cwadej
    Right Here
    2011 Access Cab 4x4
    good info, thanks. I was unaware of the 1 vs 2 way breathers.
    time for more research
    gulzeb and Boyk1182 like this.
  18. Apr 6, 2018 at 4:35 PM
    #918
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    My bed doesn't have the cubbies in the front of the bed, just remove the inner fender at the rear tire to gain access to the back? Curious how others with the 15 TRD Sport DCLB accomplished this.
  19. May 10, 2018 at 8:52 AM
    #919
    14Tacos4me
    14Tacos4me Well-Known Member
    Daniel
    Hendersonville, TN
    2014 Blue Ribbon DCSB TRD OR 4x4
    -Fox 3 inch lift -SOS Streamline front bumper with Smittybilt x20 winch -Mobtown sliders -Mobtown IFS & Trans skids -DV8 Rear bumper - Look at the build thread
    I did this a month or two back, but figured I'd share what I used. I think it cost me around $20 for everything.
    Here's the hose connected to the new union.
    I decided to mount the new breather in the storage compartment in the bed, but I'm considering moving it up by the taillight.
  20. May 10, 2018 at 8:53 AM
    #920
    Slashaar
    Josh
    Kansas City, MO
    I bought my kit from Yotashop.
