Differential breather Questions
Discussion in 'Technical Chat' started by Toy4Life, Sep 22, 2008.
  1. Sep 22, 2008 at 2:55 PM
    Toy4Life
    Toy4Life [OP] 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I've read at least a half dozen write ups on the differential breather mod. I have a couple questions, though.
    1. Can a differential breather go bad?
    2. I've seen a couple write ups that suggested using a fuel filter on the extension as opposed to the breather. Has anyone gone this route? If you did, what kind of filter did you use and where did you get it?
  2. Sep 22, 2008 at 5:52 PM
    Toy4Life
    Chad
    Slippery Rock, PA
  3. Sep 22, 2008 at 5:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have used fuel filters before. Just get one that fits the hose you are useing as the creather extension. Personally, I think a filter is better as it prevents any crap from getting into the gears. A regular breather is simmilar to a flapper valve.
  4. Sep 22, 2008 at 6:10 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Thanks Chris. I read that using a filter instead of the breather allows the differential to "breathe" easier preventing any pressure which in turn can help prevent the oil seals from leaking.
  5. Sep 22, 2008 at 6:15 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Would you leave this filter open ended or put some sort of cover on it. I would imagine it would be left open ended.
  6. Sep 22, 2008 at 6:15 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    God, I need to extend my breathers...
  7. Sep 22, 2008 at 6:18 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Open ended I believe.
  8. Sep 22, 2008 at 6:21 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    x2! I need to replace both outer axle seals (they're leaking), so I figured the breather mod will help prevent me from having to do it again anytime soon. I have the seals and 1/2 the stuff for the breather extension. I just have to get to the dealership for the union fitting.
  9. Sep 22, 2008 at 6:27 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I extended my rear diff but decided against my tranny and t-case.
  10. Sep 22, 2008 at 6:30 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Was that in one of the other threads? I think I read that today.
  11. Sep 22, 2008 at 6:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    anyone got part numbers for what us first gen guys need to extend the front and rear diffs, tranny and transfer case as well?? i really wanna do mine before the next meet, and tigerfan00 will probably wanna do his too.
  12. Sep 22, 2008 at 6:38 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I dunno if it is the same for the tranny and transfer case, but for the rear breather, you'll need:
    8ft 1/4" rubber hose
    2 small hose clamps
    1 "union" - Toyota part# 9040451026
    original breather or substitute a fuel filter that will fit the hose
    I believe the front diff is already extended up to th fender under the hood.
  13. Sep 22, 2008 at 6:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    alright,cool man. i may pick that up tomorrow since the dealer is replacing my steering rack under warranty. i already have quite a few small fuel filters here with me.
  14. Sep 22, 2008 at 6:43 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i know a lot of guys tend to use that yellow coiled air hose as it will flex a bit and not pop when your suspension flexes out
  15. Sep 22, 2008 at 6:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think i'll stick to the regular fuel line myself, you can make it long enough, and its pretty tough and abrasion resistant already, plus its probably a bit cheaper.
  16. Sep 22, 2008 at 6:49 PM
    JimBeam
    JB
    2015 Tundra
    yeah but whats the point of a functional modification if the whole world cant see it and wonder wtf its for? :D
  17. Sep 22, 2008 at 6:49 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Just under $10 for 8ft of the black rubber fuel line at Advanced.
  18. Sep 22, 2008 at 6:53 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Yeah I believe I posted that in the what have you done to your Tacoma Today thread.
  19. Sep 22, 2008 at 6:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    definitely cheaper than the hose that jeff mentioned, and easily replaceable.
  20. Sep 22, 2008 at 8:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ok, i'll install regular fuel line on my taco, you can use the yellow curly shit!!!:D
