Differential casing/housing gasket
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaFloppa, Apr 19, 2025.
  1. Apr 19, 2025 at 11:58 AM
    TacomaFloppa
    TacomaFloppa [OP] Well-Known Member
    Wondering what the OEM gasket part number was so i could order a new one.
    I read they also used gasket maker but my step dad says theres also a gasket thats made
    Also does anyone know what to google for a YouTube video of it? I know its self explanatory but I prefer a video
    4wd, 2002, full cab, e locker, the bigger axel
    https://imgur.com/a/qJzkv5J
  2. Apr 19, 2025 at 12:01 PM
    02hilux
    Planet: EARTH
    Gear oil RTV. Been without a gasket for years now and no leak issue. Clean and prep the mounting surface well and call it good.
    SpencerTacoSC likes this.
  3. Apr 19, 2025 at 12:03 PM
    TacomaFloppa
    Nice. I was also told of a redneck trick where you use the cardboard that beer comes in. It swells up and let's no oil out. Could I use that and gasket maker or would 2 gaskets do more harm than good? I just dont want to do this again
  4. Apr 19, 2025 at 12:04 PM
    02hilux
    Planet: EARTH
    This will fit if you insist on using a gasket
    42181-60130
    TacomaFloppa[OP] likes this.
  5. Apr 19, 2025 at 12:07 PM
    02hilux
    Planet: EARTH
    Seen done both way, with and without paper gasket. Like I said, prep goes a long way. Thoroughly clean both mounting surface before torquing it down and allowing the rtv to cured before pouring gear oil in. I usually get it down before night time and let it sit overnight before I add gear oil. I use
    Permatex 81182 Gear Oil RTV
  6. Apr 19, 2025 at 12:11 PM
    02hilux
    Planet: EARTH
  7. Apr 19, 2025 at 2:48 PM
    TacomaFloppa
    I see, thank you very much. Ill just make my own gasket
  8. Apr 21, 2025 at 9:40 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    The most crucial part of this is getting the surface clean before using a gasket or RTV. I've always only use RTV without gaskets with no issues. Also make sure once you applied the rtv not to torque everything down right away. Let it kind of cure a little before torquing down
