Differential Check Plug Stripped - 2004 Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by timken1111, Oct 14, 2009.
  1. Oct 14, 2009 at 7:27 PM
    timken1111
    timken1111 [OP] New Member
    Portland, OR
    07 PreRunner SR5 Double Cab
    Running Boards
    I have been told that the rear differential check plug on my 2004 Tacoma is stripped. :mad:
    Is that a serious problem for leakage? Is the check plug the same as the fill plug?:confused: Being a senior it would help to know how serious a problem this is and what can be done about it.
    Thanks
  2. Oct 14, 2009 at 7:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if its stripped.....its probably rounded off around the edges where a socket wont work on it. if you know someone with a welder...get them to weld a small piece of steel pipe onto it and then see if it can be broken free....and order another one from the dealership. and yes.....its the fill plug. its not gonna cause a leak.
  3. Oct 14, 2009 at 7:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
    If the threads are stipped, they will have to be tapped, and a new plug installed. :)
  4. Oct 14, 2009 at 8:27 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    If the threads got stripped out, it's also gonna be a bitch to get out.
  5. Oct 14, 2009 at 9:59 PM
    texasbowhunter
    texasbowhunter Third Coast
    Texas Gulf Coast
    04 Double Cab 4x4 TRD
    Tinted Windows, Moto Metal 955's, Cooper 305/70/16 STT's, Deckplate Mod.,AFE Pro Dry, Toytec Coilovers, 2" AAL, Diff. Drop, Bilstein 5100's On the Corners, Alpine 10" Sub, Alpine 305 Head, Polk Mids
    Get someone with a welder to weld a piece of pipe like 06 said. If you get a piece of pipe in the shape of T you should have enough leverage to break it loose. It will also make it a lot easier if you heat it up.
