Differential drop kit instead of ECGS clamshell Bushing??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by goose443, Jun 28, 2017.
  1. Jun 28, 2017 at 11:28 AM
    goose443
    goose443 [OP] Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    hello,
    I recently leveled my truck by raising the front end roughly 1". Since then, I have experienced very slight vibrations while driving. I know that the ECGS Bushing is known for fixing this issue, but my question is, would installing a differential drop kit also remedy the issue?? The diff drop kit is cheaper and also much easier to install. Thank you for your help! I just wanted to see if it would be as effective as the ECGS Bushing.
  2. Jun 28, 2017 at 11:34 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Diff Drops do nothing for our 2nd and 3rd Gen Tacoma's. Might be cheaper but can also cause more damage in the long run.
  3. Jun 28, 2017 at 11:37 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    No. There are numerous threads stating the drop kit does more harm than good.
    Drive in a straight line at speed and engage 4wd. If the vibes are gone, the ECGS bushing needs replaced. It's an easy check.
  4. Jan 20, 2020 at 5:26 PM
    blacktoyotatacoma
    blacktoyotatacoma Well-Known Member
    Florida
    2018 quicksand dcsb tacoma sr5
    What damage with a diff drop? It just reduces the higher angle of the cv on a lift. This should help the alignment into the differential no?
  5. Jan 20, 2020 at 5:39 PM
    blacktoyotatacoma
    Florida
    Ah i see so self induced damage. I was curious if it was a mechanical failure or something. That catasgrphically fails
  6. Jan 20, 2020 at 5:42 PM
    blacktoyotatacoma
    Florida
    Never heard of that. Jesus this forum just makes me terrified to drive the damn thing after ive lifted it
  7. Jan 20, 2020 at 5:43 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Fuck no.
    blacktoyotatacoma likes this.
  8. Jan 20, 2020 at 5:51 PM
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    I have one I’ll sell ya : )
    It did absolutely nothing !
  9. Jan 20, 2020 at 5:53 PM
    blacktoyotatacoma
    Florida
    I have a diff drop on mine. Thanks tho! Haha. With the skid plate off it does hang out like a set of fangs though
  10. Jan 20, 2020 at 7:34 PM
    gavia
    gavia Well-Known Member
    19 2.7L 4x4 BWCA Edition
    The ECGS bushing isn't too bad to do yourself. Watch a couple youtube vids and take your time.
    Superdave1.0 and whatstcp like this.
  11. Jan 20, 2020 at 8:12 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Isn't there a prop shaft angle issue too or am I imagining things?
  12. Jan 20, 2020 at 8:38 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Even a 3* shim is enough to cancel vibes in a rear driveshaft
  13. Jan 20, 2020 at 8:58 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Everybody said I would get vibrations at 35mph so I drive at 30 or 40, nowhere in between, so far so good; knock on wood.
  14. Jan 21, 2020 at 12:01 AM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    My exeperience with the bushing swap is this.
    I had minor vibrations post lift but they didn't go away in 4wd. I did however notice that there was a lot of play on my driver side cv. After installing the bushing there is much less play and no vibrations ever. It's nice having the piece of mind that I can safely run a 3" front lift and not have the bearing grenade my front diff.
