Differential Drop needed?
Discussion in 'Suspension' started by jamesnev, Dec 3, 2012.
  1. Dec 3, 2012 at 1:55 PM
    jamesnev
    jamesnev [OP] Member
    James
    British Columbia
    Hey Guys,
    New to TW, but the more time i spend on this website the more i'm starting to play around with my 2010 Tacoma TRD sport.
    I'm about to install a Skyjacker 2.5inch leveling kit and I've searched and keep coming back to the same thing: Differential drop kit or not? I cant seem to get a solid answer of what is the best despite trying the oh so famous "search" button.
    I wouldn't say i do extreme off roading, but i do head off the black top for biking, snowmobiling, and the random adventure. I do have firestone air ride in the rear to handle having my sled in the back. Other than that, everything is still factory.
    Any help would be great,
    Thanks!
  2. Dec 3, 2012 at 1:57 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Nope. Only if 4x4 and if you were going higher.
    Welcome aboard.
  3. Dec 3, 2012 at 2:05 PM
    jamesnev
    James
    British Columbia
    Thanks TrdSurgie,
    My truck is a 4X4. Does that mean i should be installing a differential drop?
    Cheers
  4. Dec 3, 2012 at 2:31 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    NOOOOO diff drop needed for 2nd gens......I know some go back and forth but it's well known that it actually causes issues!
    And dude, skyjacker spacers? You don't want your truck riding like shit bricks do you? I know they look cool but get some 5100's at 1.75" and enjoy a little lift with good shocks!
  5. Dec 3, 2012 at 2:45 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    The differential drop does help the cv angle... not alot, but anything helps.
  6. Dec 3, 2012 at 2:46 PM
    jamesnev
    James
    British Columbia
    Thanks for clearing the question that was giving me a headache.
    I really am not experienced with lifts, etc. I was going with skyjacker cause the price seemed right without emptying a bank account.
    the 5100s are simply a shock that gives me an exta 1.75?
    can i get a 5100 that gives me the 2.5? i want it to sit level with the back
  7. Dec 3, 2012 at 2:48 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
  8. Dec 3, 2012 at 3:43 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    The 5100s have 4 settings on the shock body itself....0 lift, .85", 1.75" and 2.5" but at the highest setting they'll ride pretty stiff but still better than a spacer. Lots of guys also get a longer spring to go with the shock (eibachs or OME) so they don't have to be pre-loaded as much. Search, it's been covered 1,647,7588,584,845 times...lol
    It really wouldn't cost much more to do it right!
  9. Dec 3, 2012 at 4:09 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    needed? no. recommended? yes. some say they dont do anything for second generation tacomas, i have no knowledge on that part though.
  10. Dec 3, 2012 at 4:16 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    It doesnt actually "drop" the differential. It slightly rotates/angles it down. But its not enough to make and significant difference in the cv angles.
  11. Dec 3, 2012 at 4:18 PM
    Chepo
    Chepo Tankoma!
    Mexico City
    '11 TRD Sport
    Lots...
    It is recommended due to the cv angle... But if you do other than mall crawling, you can do this CV boot mod and you will have no issues with the boot...
    In my opinion, don't waste your money on that!
  12. Dec 3, 2012 at 7:08 PM
    jamesnev
    James
    British Columbia
    Thanks for the sound advise all. Got a pretty good idea what direction to go.
  13. Dec 3, 2012 at 8:00 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Don't raise the shit out of the truck and your cv's will be fine......I've had my coilovers as high as 3.5" and cv's were still good.....no more than 3" for 4x4 is safe!
  14. Dec 4, 2012 at 4:01 PM
    jamesnev
    James
    British Columbia
    I agree Sublime. Im keeping it to a 2.5 in the front to keep it classy. Just got new tires last winter and dont really want to have to go spending more to make everything look normal (Hate that small tire/huge wheel well look)
  15. Nov 19, 2013 at 10:06 AM
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    Just piling on questions to this thread. So an '06 4x4 access cab with 5100's set at 2.5 with skyjacker add a leaf (2.5" or so) in the rear should need nothing else? What about a carrier drop an inch or so? I don't really offroad at all, and there aren't really any rocks here anyway.
  16. Nov 19, 2013 at 11:12 AM
    themuffinman619
    themuffinman
    Your moms house
    If you experience any vibrations in the rear after the add a leaf, then you can try a carrier bearing drop. Or axle shims.
